Old 03-05-2014, 12:06 PM   #11
Also Congratulations, on getting your new Tracer. We have put on 4000. miles on ours this year. I have put in the sliding drawers, under the seating area and they work great. The whole trailer works great. In those 4000. miles we never seen one more Tracer anywhere? But we did show ours off whenever possible, there was LOTs of interest in it. I installed Solar power and can run the outside frig. on it.
Your right, it is a Great Couples trailer
Careless is offline   Reply With Quote
Old 03-22-2014, 11:13 PM   #12
dgiturbo's Avatar
OK, the 2014 season is almost here. Hopefully this really long winter is finally over.
I am starting to book campsites already.
To catch up on this thread:
Bolson, I store mine inside, there is a private place in Huntley near the RV store off I90 that has indoor storage. PM me for more.
I also had my city and black tank female fittings replaced with brass, as the plastic ones were wearing out.
Careless, please more info on the solar system to run the outside fridge.
Belated congrats to all the recent owners!!!
2013 Tracer 230FBS - Traded for
2015 Crusader 335BHS Yeah baby..
dgiturbo is offline   Reply With Quote
Old 03-24-2014, 12:18 AM   #13
Hello, Please bear with me, I will try to explain this about the solar panels. the Solar Panel system installed on our 230 FBS, includes three solar panels, that can deliver up to 29 amps, that feed four six volt glass mat batteries, which are installed on the hitch, 280 pounds mind you. The power goes from there to the Coach system as normal. But, with the Inverter installed, which you can turn off and on, with the push of a button, the whole unit has 110 power, as you would have if you were plugged in, with out being plugged in. you can use any 110 plug on your unit.
We had a 2000 watt inverter installed, the fridge runs on a 1500 watt heater, with the 2000 watt inverter, we don't have to worry.
With the batteries charged above 11.5 volts this works. The batteries are very important to making this system work.
Does this help. There is more that I can explain if you would like.
This is basically how it works, Les
Old 03-27-2014, 09:31 PM   #14
[QUOTE=
This is basically how it works, Les[/QUOTE]
We have a 230 FBS also and my long range plans include adding solar. I'd love to here details on how you installed the system and what components you selected. In particular, how did you bring the cables down from the roof? My Tracer has the fiberglass front cap, and I've wondered if there is enough space behind it to run cables. Pictures would be great
Roamin Ovum is offline   Reply With Quote
Old 04-21-2014, 05:45 AM   #15
Question Our new Tracer 230 FBS camper!
We just picked up our new Tracer 230FBS camper and are just now going through it, getting familiar with every thing AND discovered we are having troubles opening the windows. They look like they slide up & down, but we can't get them to move very well and I didn't want to force it. Anybody with a Tracer that's run into this??? Thanks.
57 Chevy Dan is offline   Reply With Quote
Old 04-21-2014, 06:32 AM   #16
RollingDownTheHighway's Avatar
we have a tracer 3200 bht exc. series and we love it. We do what others mentioned with the outside shower running hot water through the black tank when flushing it out it. Works great. We've done 2 trips with ours so far and love it.
2013 Prime Time Tracer 3200BHT
2016 Chevy 3500 CC, DRW (aka: bigbootyjudy)
Ribs in the smoker and Whiskey in hand
RollingDownTheHighway is offline   Reply With Quote
Old 05-04-2014, 09:03 PM   #17
Sticky Windows
Yes the windows are sticky, with carefull determination we got them open, good luck with your windows.
Les
Old 05-04-2014, 09:36 PM   #18
Solar
Hi there, Umm I cheated this time and had the whole system installed, in Quartzite Arizonia, they do it all winter every year, they know what they are doing, I have done it before but not this time. They run the wires down the fridge vent and then right through the floor and under the unit to the batteries, which I installed behind the propane tanks. I used 4 - 6 volt Glass Matt batteries, $250.00 each. They are like the Heart of the system, so I went all the way with them. The solar panels are three K D 140's , I believe they are built in Canada, sold in Arizonia, Can get up to 30 amps with these, $1000.00 the control panel is a New Model last year, made by Blue Sky, $280.00 it can handle the 30 amps, and has a Solar Booster, sorry, I cant explain that properly, but, it gives you extra power from your solar panels. The inverter is a ProWatt SW 2000, $400.00. transfer switch, when then inverter is turned on, $95.00. 300 amp fuse, for the inverter $70.00.
The list goes on for awhile yet. there is the cost of the wire and a remote switch, temperature sensor, tilts for the panels that's just about it there.
The system works very well, I don't need to have a Generator anymore, I have used a Battery Charger from Wal Mart to charge the Battery for the electric motor for my boat, I can watch T.V. use the toaster, use the furnace in my rig, things like that. I am going to attach some pictures.
ID:	51651   Click image for larger version
ID:	51652   Click image for larger version
ID:	51653   Click image for larger version
ID:	51654   Click image for larger version
Old 05-05-2014, 08:26 AM   #19
Les
Mine are sticky too, on a Tracer 230. I keep meaning to use some Kendall Door Eaze on the tracks, but keep forgetting to pack it. If it works I'll post it.
Old 05-05-2014, 08:29 AM   #20
Thanks for the post and pics! Are the panels wired in series or parallel? Do you know what the voltage in the line from the panels and gauge of the wires are?
Thanks again for the advise.
