Old 09-30-2013, 05:36 PM   #1
07 ThunderRoad's Avatar
What good is the HW tank bypass valve on the Anderson docking station?
After repairing a major flood in the basement of our coach, I looked at the plumbing of the Anderson docking center. The hot water bypass valve, on the right, bypassed the fresh water around the hot water tank. This causes the hot water tank piping to remain isolated from the system when adding antifreeze. What good is this valve? Is it possible our coach is piped wrong?
2013 Sanibel 3600 5th, 2007Dodge 2500 Cummins Turbo Diesel, 2WD, 4.10gears, Banks equipped, 18" factory rims
07 ThunderRoad is offline   Reply With Quote
Old 09-30-2013, 05:46 PM   #2
schrederman's Avatar
I will drain my system as good as I can first, including removing the anode rod and letting the HW tank drain. That will usually drain those lines. Not saying it will for your rig, since I have no clue how it's plumbed.
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
schrederman is offline   Reply With Quote
Old 09-30-2013, 06:00 PM   #3
Ford Idaho's Avatar
How big is your heater 6-10 gallons?
At about 3 bucks a gallon do you really want to fill the tank?
Old 09-30-2013, 06:08 PM   #4
KyDan's Avatar
He's NOT filling his HW tank.
I drain my water heater and then blow the system out with air.
This removes the water from the bypass area.
Then I close the tank valves and open the bypass and pump the
system full of the pink stuff.
Works for me.
YMMV
Peace!
Dan & Rita D
2004 5.3L Silverado 1500 ext. cab 2WD
Blue Ox WD hitch, AirLift load levelers
2013-41, 2014-31, 2015-40, 2016-44, 2017-63
Old 09-30-2013, 06:10 PM   #5
The HW tank has the bypass valve on the back of it. This is what I don't understand. The bypass valves are on the HW tank for draining and adding antifreeze. Why do I need the Anderson HW bypass. The only use I see is it takes the HW tank out of the pressurized plumbing system when the coach is in use.
Old 09-30-2013, 06:13 PM   #6
Ford Idaho's Avatar
Works for me.
YMMV
I know!
Old 09-30-2013, 07:46 PM   #7
Send a message via MSN to Tiggerdad
The bypass valve is designed to be open with the inlet and outlet valves to be closed to keep the tank from receiving antifreeze during weatherization. HW heaters with antifreeze in them can be harder to flush to get the taste out. Heater still must be drained for the winter if bypassed. I would drain for winter whether antifreeze is added or not.
One does not have to bypass the tank if you so desire.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 09-30-2013, 08:22 PM   #8
This valve is so during winterizing you can bypass the tank and not be filling it with antifreeze. I drain my tank, then pressurize the water system with air and blow out all the lines, then switch my hot water bypass to shut off the hot water tank and bypass it. Then pump the antifreeze thru the system, less the hot water tank.
~Andrew
99 F250 Super Cab Short Bed 7.3 Powerstroke
84 24' Yellowstone Camino (oldie)
http://rvpdi.com
Acableguy06 is offline   Reply With Quote
Old 09-30-2013, 08:29 PM   #9
saves a ton of the pink stuff if you pull out anode rod tank will be empty no reason to put pink stuff in it
jkklops is offline   Reply With Quote
Old 09-30-2013, 08:54 PM   #10
If I'm reading your post correctly you have 2 separate bypass valves for your water heater. If it was me I would leave the one at the panel normal and use the one right on the tank. That way all your lines are covered.
2008 Rockwood 8281ss
2006 Dodge Ram Mega Cab Hemi
Reese 15k Slider
mikegp1 is offline   Reply With Quote
tank
