Old 04-15-2014, 10:45 AM   #11
Originally Posted by MtnGuy View Post
...If you are doing the fender measurements and not inflating airbags, then I don't see how those measurements are possible. When you hook up 1000 lbs. to your truck, then something has got to settle.
Don't remember the tongue wt on our tt, but with the bars engaged, the front fender measurements were around 1/8"-1/4" lower and the rear was about the same amount. In other words, the whole truck lowered around 1/8"-1/4".
The 5er does about the same but I have to air up the airbags to get it back to unloaded height.
Old 04-15-2014, 12:59 PM   #12
fonzie's Avatar
I'm using ProPride 3P hitch with 1400lbs bars and no sway.......
Trailer Sway Control Hitch Guaranteed to Eliminate Trailer Sway - ProPride 3P
Fonzie
Old 04-15-2014, 01:24 PM   #13
DDC
DDC's Avatar
I use a Hensley, unit is level and no sway.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 04-15-2014, 01:26 PM   #14
shadow7663's Avatar
UPDATE!!!! Issue resolved
This was eating me alive so I just couldn't wait any longer. After further inspection I noticed the passenger side "L" bracket was one hole lower than the drivers side.....(my fault) Raised it to match the drivers side went on a test run. It was noticeably better but still a tad bit of sway in 18-20mph wind gusts. Made another adjustment mid trip by raising BOTH "L" brackets another notch and bingo sway is gone.
Did another set of measurements and found after my last adjustment the rear of the truck is sitting 3/4 of an inch lower then when it's empty and steer axle stayed the same as when empty. Thanks again for all of the replies and hope someone can learn from my mistake....LOL
shadow7663 is offline   Reply With Quote
Old 04-16-2014, 12:25 PM   #15
Platokidd's Avatar
equal-I-zer 14k on my long tt , works good and no sway!
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 04-16-2014, 12:28 PM   #16
Platokidd's Avatar
Chevy recommends not to have the front squat lower then stock height.
nights of camping
Seasonal
hitch, trailer
