Old 09-10-2014, 08:34 AM   #31
Infractee
As has been stated many times all over these forums, you will run out of cargo/pin weight long before towing capacity, especially on an F250.
*Most* Newer F250 GVW is at 10K, and the SRW F350 is at 11.5K
Which is great for pin capacity as the SRW F350 only weighs 100~200 lbs more than comparable F250 which nets you an additional 1300~1400 lbs cargo cap.
RhoZeta is offline   Reply With Quote
sanibel, tow vehicle
