Originally Posted by TTNewbees
Structure might be a harsh word but the cabinet doors are falling off everywhere and every screw that secures hinges are all crooked and don't bite well.
As a side note the black tank says it full, it ain't unless it's not draining.
So here is a question for the group, although all minor and having camped for 4 days total, do you take to dealer to replace all hinges/crooked screws and look at black tank? I aint got Herk skills to drop tanks and replace sensors.
You might (if you want to) replace all those screws that you're finding with a slightly larger screw from your local hardware store or Lowes or Home depot. ( I did) They should have colored screws that match the hinges. Just don't get them too long that they go all the way through to the inside of the cabinet.
My grey and black sensor also are giving false readings. I'm going to have to try the "Calgon" treatment and see if that will help clean the crud off the sensors. Of course, one way to know if your black tank is empty is to open the toilet valve with the water off and the TT level and look down into the tank. If you can see the bottom of the tank and it's dry then, it's probably pretty empty.
But, if it's not a hassle to take your TT to your dealer then, by all means take it in.
Good luck and
2014 Prime Time Sanibel 3250
