Old 03-16-2011, 09:43 PM   #11
Originally Posted by rracer5 View Post
Actually, that's my problem. I can't find a hose or fitting to fit my "red" road trip grill if I remove the regulator......HELP?
The hose I got has a brass fitting that screws onto where the regulator would normally screw onto. This fitting looks like a standard size fitting that could be found at an Ace, Orchard, True Value, etc. It seems like it will work, but I won't know until I bring the trailer home again. Also, I was looking on the box but it does not give the size of the fitting, it only indicates that it has a Hansen quick disconnect. The hose is from a canadian company called GrillPro. Sorry I could not give you more specifics.
2014 Ram 2500 Laramie CC 6.4l Hemi
2011 LaCrosse 296BHS
autorot8 is offline   Reply With Quote
Old 03-18-2011, 01:55 PM   #12
Well, so much for the hose I found at Orchard as the quick disconnect would not fit the QD on the trailer. I have tried everywhere in my area, and this part cannot be found. Sorta makes this great feature useless.
Old 03-18-2011, 09:11 PM   #13
rracer5's Avatar
How about the end that attaches to the grill? Did that end work? And what part of the QC is not the right size (diameter or length) does it click in or seems to bottom out before lockung in?
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 03-18-2011, 09:27 PM   #14
sherdep's Avatar
I have seen the quick disconnect ends at camping world but not sure if that will help your quest or not
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 03-18-2011, 10:07 PM   #15
The end that attaches to the grill worked, but the QC was too big diameter to fit into the QD on the trailer.
Old 03-19-2011, 08:42 AM   #16
I believe that all campers have a 1/4 inch QC--Probally the one you bought is to hook a grill up to house natural gas (they are 3/8 inch)
ayotte is offline   Reply With Quote
Old 03-20-2011, 06:30 PM   #17
rracer5's Avatar
If possible, could please post a pic of the grill side connector end? That is the end I can't find.
2014 Sanibel 3250
Old 03-20-2011, 06:57 PM   #18
Camping world has the hose (about $15) and also the adapters .
NE_Roo_lvrs is offline   Reply With Quote
Old 03-21-2011, 06:45 AM   #19
The Road Trip grill takes a 3/8" flare female fitting. I eventually found a Camco 4100 kit at a truck accessory store (although it had been sitting on the shelf for quite a while). It has the QD that fits the TT, the other end has a valve with a 1/4" flare male fitting. Although I don't need the valve, it was all I could find that did not have a regulator on it. I went to the local hardware store and used a couple brass fittings to go from the 1/4" male to the 3/8" female. It screws onto the grill, just have not tried it out yet. I'll post a pic as soon as I am able.
Old 03-21-2011, 08:05 AM   #20
Campster's Avatar
Camp Chef has them.
Campster is offline   Reply With Quote
