Old 03-21-2011, 10:58 AM   #21
rracer5's Avatar
Originally Posted by autorot8 View Post
The Road Trip grill takes a 3/8" flare female fitting. I eventually found a Camco 4100 kit at a truck accessory store (although it had been sitting on the shelf for quite a while). It has the QD that fits the TT, the other end has a valve with a 1/4" flare male fitting. Although I don't need the valve, it was all I could find that did not have a regulator on it. I went to the local hardware store and used a couple brass fittings to go from the 1/4" male to the 3/8" female. It screws onto the grill, just have not tried it out yet. I'll post a pic as soon as I am able.
Do you have the red Road Trip with wheels or the blue with the stationary stand legs? I haven't been able to look closely at the blue one yet but, I'm feeling that the grill side connections are different which is why I think I'm having such a hard time finding one. I'll wait for your pic and post one of mine when I get it out of the TT that's in storage.
Thanks!!!!
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 03-21-2011, 11:07 AM   #22
Mine is actually black with wheels, which is an updated 10th anniversary model of the red one.
2014 Ram 2500 Laramie CC 6.4l Hemi
2011 LaCrosse 296BHS
autorot8 is offline   Reply With Quote
Old 03-21-2011, 03:16 PM   #23
rracer5's Avatar
Thanks!!!!
This is what I'm dealing with......
ID:	4949   Click image for larger version
ID:	4950   Click image for larger version
2014 Sanibel 3250
Old 03-21-2011, 07:25 PM   #24
rracer5, hopefully this helps. This is the hose I have which fits both the trailer and my road trip grill. Essentially the brass fitting (3/8" female coupling) screws directly onto the grill, without using the regulator that comes with the grill (mine looks just like the one in your pictures). Although there is a valve on the hose(could not bypass), I will just keep it on high when using the grill since it is just a valve and NOT a regulator. The connection kit designed to be connected to a trailer supply line, post regulator (according to package). Now, I do not know if it actually works, but everything connects and it appears it should work.
ID:	4952   Click image for larger version
ID:	4953   Click image for larger version
Old 03-21-2011, 09:23 PM   #25
rracer5's Avatar
Thanks. Now I can see what I have to put together.
Oh, and before you light it, check for leaks with soapy water....I will too.
2014 Sanibel 3250
