03-12-2011, 06:17 PM
Where did you get your quick disconnect propane hose?
I want to connect my road trip grill to the quick disconnect propane line that comes with all PTM RVs, but cannot find a hose with the quick disconnect. For those that are using this feature, where did you get your hose? Thanks in advance for your assistance.
2014 Ram 2500 Laramie CC 6.4l Hemi
2011 LaCrosse 296BHS
03-12-2011, 06:30 PM
Any decent B.Q. shop should have it, I got mine at B.B.Q. Galore. Just tell them it's for a travel trailer, from what I am told all RV's use the same size.
Heinrich and Elly
2010 Prime Time Tracer 205M
2010 Dodge Dakota Crewcab 4.7 l
03-16-2011, 05:07 PM
2014 Prime Time Sanibel 3250
03-16-2011, 05:24 PM
I just found a hose at orchard, one end QD, the other will screw directly onto the grill. hopefully it will work.
03-16-2011, 05:47 PM
AKA Bluebird
Sorry, but I am quite sure rracer5 gave you an accurate answer.
03-16-2011, 06:21 PM
Actually, rracer5 indicated he was using both regulators, I am not. I am screwing the hose directly into the grill, thus bypassing the regulator that comes with the grill.
03-16-2011, 07:05 PM
Can you get 3-4ft extension hose with quickconnect on both ends?
03-16-2011, 07:34 PM
I had a burner with a regulator on the end of the hose which i removed and replaced with a male quick connect i purchased at Ace Hardware... darn male quick connect is just ever so slightly too large for the female connector on the trailer.... grrrr. Are the TT QC's a diff size then the standard grill QC's?
2011 Heritage Glenn 312QBUD
2011 F-350 SRW Lariat FX4
2014 Sandpiper 365SAQB
03-16-2011, 07:43 PM
Grape Escape
Home Depot natural gas hose for BBQ approx 15' long if I recall
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
03-16-2011, 08:16 PM
Actually, that's my problem. I can't find a hose or fitting to fit my "red" road trip grill if I remove the regulator......HELP?
03-16-2011, 09:43 PM
The hose I got has a brass fitting that screws onto where the regulator would normally screw onto. This fitting looks like a standard size fitting that could be found at an Ace, Orchard, True Value, etc. It seems like it will work, but I won't know until I bring the trailer home again. Also, I was looking on the box but it does not give the size of the fitting, it only indicates that it has a Hansen quick disconnect. The hose is from a canadian company called GrillPro. Sorry I could not give you more specifics.
03-18-2011, 01:55 PM
Well, so much for the hose I found at Orchard as the quick disconnect would not fit the QD on the trailer. I have tried everywhere in my area, and this part cannot be found. Sorta makes this great feature useless.
03-18-2011, 09:11 PM
How about the end that attaches to the grill? Did that end work? And what part of the QC is not the right size (diameter or length) does it click in or seems to bottom out before lockung in?
03-18-2011, 09:27 PM
I have seen the quick disconnect ends at camping world but not sure if that will help your quest or not
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
03-18-2011, 10:07 PM
The end that attaches to the grill worked, but the QC was too big diameter to fit into the QD on the trailer.
03-19-2011, 08:42 AM
I believe that all campers have a 1/4 inch QC--Probally the one you bought is to hook a grill up to house natural gas (they are 3/8 inch)
03-20-2011, 06:30 PM
If possible, could please post a pic of the grill side connector end? That is the end I can't find.
03-20-2011, 06:57 PM
Camping world has the hose (about $15) and also the adapters .
03-21-2011, 06:45 AM
The Road Trip grill takes a 3/8" flare female fitting. I eventually found a Camco 4100 kit at a truck accessory store (although it had been sitting on the shelf for quite a while). It has the QD that fits the TT, the other end has a valve with a 1/4" flare male fitting. Although I don't need the valve, it was all I could find that did not have a regulator on it. I went to the local hardware store and used a couple brass fittings to go from the 1/4" male to the 3/8" female. It screws onto the grill, just have not tried it out yet. I'll post a pic as soon as I am able.
03-21-2011, 08:05 AM
Camp Chef has them.
