Old 04-30-2013, 09:29 PM   #1
07 ThunderRoad's Avatar
Where does the 3rd satellite connection go to?
We have a Sanibel 3600 with the 3 satellite connectors in the docking center. I have identified the bedroom and living room connectors but can't find a connector at the outside tv. What is the 3rd connector going to?
2013 Sanibel 3600 5th, 2007Dodge 2500 Cummins Turbo Diesel, 2WD, 4.10gears, Banks equipped, 18" factory rims
07 ThunderRoad is offline   Reply With Quote
Old 04-30-2013, 09:40 PM   #2
Fire Instructor's Avatar
Is there an outside connection? Or one in one of the compartments for an outside television?
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 04-30-2013, 11:21 PM   #3
It really says Satellite and and not "Cable"?
Old 05-01-2013, 05:54 AM   #4
Commercial Member
One - Cable
Two - Downstairs Sat
Three - Bedroom Sat
PTM
RV Guy is offline   Reply With Quote
Old 05-01-2013, 09:00 AM   #5
Thunder,
so there isn't a separate satellite receiver connection for the outside TV, but there are ways to view the living room Sat receiver output on that outside TV. (Ask if you need more details on that, and indicate which Sat company and receiver you use.)
The "Cable" input you see in the convenience center is wired to the back of the Winegard antenna amplifier control (behind the living room TV?).
Old 05-01-2013, 04:43 PM   #6
Originally Posted by RV Guy View Post
One - Cable
Three - Bedroom Sat
PTM
None of the connectors are marked in the docking center. Sooo... I whipped out my trusty P-Touch label maker and was going crazy labeling every thing, uhh..ya.. for my DW.
Is there a switch for ant to cable on the wall jack like our 2003 Potomac? All I found was the booster button.
Old 05-01-2013, 05:23 PM   #7
The "booster button" also serves to switch between cable and off-the-air. Try it, you'll like it.
