Old 06-06-2019, 02:59 PM   #1
Where to place jack when changing tire
I have a 2018 315RST Crusader. Can someone please tell me the proper place to jack the unit without causing damage? My owners manual does not address this. Some say to place under axle near or on u-bolt and others say to place the jack against the frame. Any info would be appreciated.
DeltaMud is offline   Reply With Quote
Old 06-06-2019, 03:25 PM   #2
Either place should be ok, just don't lift at the center of the axle. Which you use depends on the type of jack you are using, the terrain the jack is resting on and the amount of lift the jack has.
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 06-06-2019, 03:36 PM   #3
Fulltime family RVer
I'm no mechanic. I'm not even handy. So, take my advice for what you paid for it.
My take is that the axle tube is already supporting all of the weight at the U-bolts. So I jack between them or right next to them.
I really would like to have a "U" cradle made to straddle the U-bolt and curve up around the axle. But I haven't gotten around to asking anyone for it yet.
I also need to try out using my leveling system for this. Supposedly it's the easiest way!
ependydad is online now   Reply With Quote
Old 06-06-2019, 04:04 PM   #4
Iwannacamp's Avatar
here you go...
https://safejacks.com/products/axle-...or-bottle-jack
or... welding required
https://www.amazon.com/SWAG-Road-Bot.../dp/B00LBFPN82
2017 Puma 297RLSS
Old 06-06-2019, 04:10 PM   #5
I've had to change 2 tires on the side of the road over the years. I use the orange blocks that are stackable to make a " ramp" and then back onto or pull onto depending on the circumstances until the flat tire is suspended. Change then drive off ramp.
Greg in Michigan
2019 Rockwood 2507S
2004 Nissan Titan
Camping since 1992
Greg in michigan is offline   Reply With Quote
Old 06-06-2019, 05:46 PM   #6
Homebrew's Avatar
Greg in Michigan
Great idea !
Last tire I raised the side of the trailer with the leveling system.
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is offline   Reply With Quote
Old 06-06-2019, 06:42 PM   #7
CZNEDY's Avatar
Best thing to do is get out your wood blocks and drive the trailer tires up on them and stabilize the RV and get the flat tire off the ground. Once you have it there, less jacking required. Stabilize the RV with stabilizing jacks if you don't have leveling jacks. Stabilizing jacks are not really made for lifting the RV. Then you can jack the RV up enough to get the inflated tire on.
2018 BERKSHIRE 34 QS
2016 Jeep Wrangler 75th and a
Cooler full of good ideas
Days Camped, Not Enough
CZNEDY is offline   Reply With Quote
Old 06-07-2019, 12:34 PM   #8
Jacking a Trailer
I had built, a half round 4" long piece that mounts on the top of my bottle jack. It snugly fits the OD of the axle. Then I place it as close to the axle end as possible. To me, its much safer than placing the jack under a spring or other flat area.
JimMorrell is offline   Reply With Quote
Old 06-07-2019, 12:42 PM   #9
CentralMePistol's Avatar
Originally Posted by Iwannacamp View Post
At those prices... Rapid Jack?
https://www.amazon.com/Andersen-Manu...gateway&sr=8-3
2018 Cherokee 274DBH
2012 GMC Sierra 1500
4x4, Crew Cab, 5.3 KDL HD Cooling, 3.42 ratio
Recurve R6 WDH w/Sway Control & SumoSprings
Days Camped:2019-18 and counting / 2018-30
CentralMePistol is offline   Reply With Quote
Old 06-07-2019, 12:48 PM   #10
Using the leveling ramps is definately the way to go in my opinion. No crawling under rig, Safe, easy. Only one experience but easier than any tire change that I have ever done on an auto.
gbaldwin is online now   Reply With Quote
tire
