View Poll Results: Material protecting underside of slide failing
Avenger Line 2 4.35%
Tracer Line 9 19.57%
Lacrose Line 6 13.04%
Crusader Line 18 39.13%
Sanibel Line 4 8.70%
Other make 7 15.22%
Voters: 46. You may not vote on this poll
Old 09-04-2013, 07:43 AM   #11
Originally Posted by OakHillFarm View Post
2014 Lacrosse 327 RES. Both the kitchen slide and dining room slide have started to fray. Bedroom slide is a different type AND has rollers under it. I will bring this to the dealer's attention, along with RV Guy"s post when I go in for my other warranty repairs.
Our slide has rollers, and the edges are still fraying. The rollers aren't the problem though. It's the material they wrapped the edges with.
brianjames is offline   Reply With Quote
Old 09-04-2013, 07:51 AM   #12
Lynkage's Avatar
3 out of our 4 slides are wearing in different areas. Only the swintek slide is ok.
Crusader 355bhq
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
Lynkage is offline   Reply With Quote
Old 09-04-2013, 12:43 PM   #13
GeoArm's Avatar
Originally Posted by Sgt. Schultz View Post
Just curious as to which lines / models have the issue with the materials protecting the underside of the slides
2013 295 rst te right side slide refrigerator and entertainment slide
2012 Ram 2500 Hemi
2013 PT Crusader 295RST TE
GeoArm is offline   Reply With Quote
Old 09-07-2013, 08:42 AM   #14
Sgt. Schultz's Avatar
Well I might have to add an Avenger to this --- Went to pick the camper from the dealer after getting the slide gaskets resealed & checked underneath --- found that the street side tires had been rubbing against the material leaving exposed wood
Not sure what to do at this time - left the camper at the dealers for now
PT Avenger 33BHS-TE
GMC 2500HD SLE 4x4 Crew Cab 6.0 with 4.10's
Sgt. Schultz is offline   Reply With Quote
Old 09-08-2013, 02:32 PM   #15
Platokidd's Avatar
That really sucks! Are you over loaded?
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 09-08-2013, 03:21 PM   #16
WJC
Sgt. Schultz I had same problem with my tracer, prime time replaced my springs and equalizers they said the springs went flat? I had about an inch clearance between tires and wheel well, this raised the trailer up about 1/2 inch, still get rub marks but not as bad, but now my tires wear really bad, axles must be really out of alignment, dealer wanted $ 700.00 to align, contacted prime time they basiclally said its my problem would not help, be sure you get it fixed before warranty is up or you will be stuck like me! Good luck!
WJC
Dodge Durango 5.7 Hemi
2010 Primetime Tracer 3000 BHS Lemon
WJC is offline   Reply With Quote
Old 09-08-2013, 05:10 PM   #17
Angry
Ready to camp we are ~ 300 lbs under the sticker max GVW it is empty at the dealers so ~ 600 lbs under right now.
WJC the unit is new - so yes this will need to be remedied under warranty!
PT Avenger 33BHS-TE
Old 09-08-2013, 07:20 PM   #18
Platokidd's Avatar
Best of luck getting it all fixed!
nights of camping
Seasonal
Old 09-16-2013, 04:51 PM   #19
Well repairs to my camper remains in warranty wonder land -- PTM and Dexter -- dealer believes at least one set of springs may be flat & it appears to be the only one with springs under the axles vs the others we looked at which have the springs over the axles
-- but on a happier note response to this poll suggests that not a lot of people are having issues with the underside of the slides vs. the number of PTM members here.
PT Avenger 33BHS-TE
Old 09-16-2013, 07:37 PM   #20
LKicklight's Avatar
Dinnett Slide
While at Goshen, the factory tech's came out and repaired this particular slide. So well in fact, it now closes almost completely flat against the coach siding. The only thing stopping from actually fitting flat all the way around is the horizontal molding that runs down the side. If the molding stopped right before the awning side, it would fit perfectly. I am planning on trimming that molding back to allow the slide to fit correctly even more.
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
prime time, slide, slide out
