View Poll Results: Material protecting underside of slide failing
Avenger Line 2 4.35%
Tracer Line 9 19.57%
Lacrose Line 6 13.04%
Crusader Line 18 39.13%
Sanibel Line 4 8.70%
Other make 7 15.22%
Voters: 46. You may not vote on this poll
Old 09-16-2013, 07:56 PM   #21
Platokidd's Avatar
Originally Posted by LKicklight View Post
While at Goshen, the factory tech's came out and repaired this particular slide. So well in fact, it now closes almost completely flat against the coach siding. The only thing stopping from actually fitting flat all the way around is the horizontal molding that runs down the side. If the molding stopped right before the awning side, it would fit perfectly. I am planning on trimming that molding back to allow the slide to fit correctly even more.
Mine always close fine. it the FloorBrace / darco fabric, taped ends underside wear thats is the issue.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 07-28-2017, 08:48 PM   #22
2014 Sanibel 3551
Moochie6903 is offline   Reply With Quote
Old 07-28-2017, 11:04 PM   #23
2016 Crusader 296BHS
esmoglo is offline   Reply With Quote
Old 08-06-2017, 06:56 PM   #24
GeoArm's Avatar
2013 Crusader 295 RST TE, kitchen, right side, slide, front
2012 Ram 2500 Hemi
2013 PT Crusader 295RST TE
GeoArm is offline   Reply With Quote
Old 08-08-2017, 02:26 PM   #25
Brendon37's Avatar
2017 crusader 315 rst no wear on any slides
2013 Ford F-250 CCSB 6.7 Diesel 4x4 w/ camper pkg
2017 Prime Time Crusader 315rst
Pullrite Super 5th 16k non-slider
Timbren SES
Brendon37 is online now   Reply With Quote
Old 08-25-2017, 10:17 PM   #26
wicked1's Avatar
Do you have to go to the event or can you call PT and bring your unit out there for the fix,
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
prime time, slide, slide out
