06-22-2012, 10:46 PM
Which tank is which
I just bought a new lacrosse 292bhs and am wondering which valve belongs to which tank as they are not labelled black or grey and both shut offs are black any help here would be great as I'm leaving first thing in the morning
06-22-2012, 10:53 PM
Missing Link
The tank directly below toilet is black.
2014 Puma 30-DBSS
2014 Ram 2500 Mega Cab 6.4L
06-22-2012, 10:55 PM
If they are two different sizes the larger is black water. Every trailer I have had, was made that way.
2012 Rockwood Windjammer 3008 W
2020 Tundra Dbl Cab 4X4 SR5
06-22-2012, 10:57 PM
The same is with my trailer and also the black tank pipe is larger.
Formerly owned 2011 Salem Cruise Lite 20RBXL & 2011 Toyota Tundra Dbl Cab
06-22-2012, 11:00 PM
The dump valve controlling the 3 inch pipe is the black tank. The dump valve controlling the 1.5 inch pipe is the gray tank. Doesn't matter where they are under the trailer, but the black will be directly under the toilet. As for dumping, black first, and then gray to wash the hose out.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
06-23-2012, 11:23 PM
Well is it the front handle or the back handle as our trailer has a heated under carriage and is totally covered you can not see any of the plumbing and the shut offs are right beside each other
06-24-2012, 12:02 AM
If the tanks have not been used you could test them by opening a valve and having someone flush the toilet. Suggest you swing by your dealer or Camping World or RV store and pick up a clear elbow for the dump valve.
06-24-2012, 07:01 AM
Check with Primtime, they will give you the info you need, they are very good about that.
2006 Silverado 2500HD
2007 Hensley Arrow Hitch
Good Sams Club
Cedar Creek Sams President
RVing is a tough job,BUT someone has to do it!
06-24-2012, 07:07 AM
Just looked at your floorplan and I would guess the valve towards the hitch is your blacktank, just a guess tho. Maybe some of the other 292bhs owners will let you know. Like another post mentioned, put a little water in one of the tanks and pull a valve open to determine which is which.
Good Sams Club
I guess if all else fails, and you have used the toilets and sinks.......
Go to a dump station, hook up your hose, and start with one valve, then close and go to the next.....between the two smells during draining.....you will have your answer
2012 Ford F-350 6.7L CC SRW w/FX4
2013 Forest River Sierra 365SAQ
06-24-2012, 08:42 AM
Lol not. Or the manufacturer could have labelled them that kinda would made sense
06-24-2012, 09:26 AM
Our lacrosse has the grey lever towards the hitch end. black toward the back. I dont think mine are labeled but the lever itself has a gray color insert in the t-handle to show its gray water
2013 Primetime Lacrosse 318BHS
2008 F-250 Powerstroke
