Old 08-03-2016, 09:10 PM   #1
Who has added a rear receiver hitch to their Crusader?
Hi. My Crusader 295rst is now one year old. I am thinking about triple towing a small Haulmark utility trail for art shows. The Haulmark gvwr is 2900#. TV is rated 18k# on a fiver.
My concern is the added rear hitch. I'm using the shop my dealer recommend. They do quite a few of these receivers.
Who has added a hitch, have you had problems and was your hitch welded in or bolt on.
Randy-2198 is offline   Reply With Quote
Old 08-03-2016, 09:13 PM   #2
Added info. The shop that would do the work mentioned they will tie in almost to the rear axle. This is not a bumper hitch.
Old 08-03-2016, 09:17 PM   #3
fast murray's Avatar
I have one on our Wildcat. I tow a decent sized BBQ pit more often than not. I haven't had any trouble. I added a cheap PEAK backup camera wired into the lights so I can keep an eye on tires and such. Its mounted under the rear bumper of the Wildcat. The ratio around here would lean pretty strong toward campers with hitches pulling boats.
2004 Wildcat 28BH
2012 Ram 2500 CCSB 6.7CTD
fast murray is offline   Reply With Quote
Old 08-03-2016, 10:50 PM   #4
Good idea on the camera.
Old 08-04-2016, 09:00 AM   #5
chesbass
I was told that bolting on is better than welding because the welding compromises the integrity of the frame
chesba88 is offline   Reply With Quote
Old 08-04-2016, 09:08 AM   #6
Do you know if yours is welded on or bolted on?
Old 08-04-2016, 04:47 PM   #7
King of the Road
I had a welded hitch receiver added to my Crusader Lite 27RK through the dealers certified and approved hitch shop. It has been rated for 400lbs of cargo weight or tongue weight and for 1000lbs towing.
So far no issues at all, but you should make sure that whatever solution you choose is approved by manufacturer(s) to prevent future headaches. You're dealer can work with you on that. If you bought private sale, you will have to do the leg work.
2016 Crusader Lite
Single slide
2013 Ram 2500 Crew Cab Tow Vehicle
Dano1955 is offline   Reply With Quote
Old 08-04-2016, 05:15 PM   #8
Thanks for the info. I am using the welder who was recommended by my dealer. Since I go out if warranty in 10 days, the mfg wouldn't cover anyway. The hitch is tied back 36-42" and has two cross members. Both cross members will be gusseted in. Verbal on 400# tongue wr and 4000 gvr.
Old 08-04-2016, 05:33 PM   #9
Georgia Frog Rally 2017
aceinspp's Avatar
I guess Colo allows this type of towing? Lot of states do not. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped so far 2017 27
Days booked so far in 2017 37
aceinspp is online now   Reply With Quote
Old 08-04-2016, 05:51 PM   #10
Yes. Most western states do. Calif requires a commercial license, none in Washington. We will be mostly Colorado, Kansas and Arizona.
crusader, hitch
