Old 05-27-2016, 09:33 AM   #1
Windows on sanibel
We have a 2013 sanibel 3501. The windows are very hard to operate for us. Trying to push the locks toward each other and lift at the same time is very difficult. Has anyone else experienced this , and if so , is there any solution. ? Thanks for any help.
chris woznica is offline   Reply With Quote
Old 05-27-2016, 12:57 PM   #2
clr
My wife has the same problem with our windows. The fix I use is to clean the tracks very good, they collect dirt and dust. Then I spray the tracks with CRC with PTFE lubricant this stuff is like liquid ball bearings. This will last quite a while but you will have to then redo the fix.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 06-02-2016, 03:06 PM   #3
same problem in my 2016 Crusader 315 they're going to replace one and they widened the track on the other the factory said no lube should be needed
colo native is offline   Reply With Quote
Old 08-19-2016, 11:13 AM   #4
emmyoscar's Avatar
We also have a 2013 Sanibel 3400 which we love. However, agree that the windows are extremely difficult to open and clean! They require two of us to open! I hope they changed them in later Sanibel models.
emmyoscar is offline   Reply With Quote
Old 08-19-2016, 09:21 PM   #5
King of the Road
My 2016 27RK is the same. One window won't even open (thankfully it's not the other way around). My dealer is replacing it, but some work smoothly with little effort and others are hard to open and close.
2016 Crusader Lite
Single slide
2013 Ram 2500 Crew Cab Tow Vehicle
2016 days camped = 91, 2017 days camped = 109
Dano1955 is offline   Reply With Quote
sanibel
