Old 10-11-2015, 09:25 PM   #1
Winter storage
My trailer is a 2015 Sanibel with a six point hydraulic stabilizer setup.
Question: Over the winter do you leave the front legs down, or do you put the front of the trailer on blocks and retract the hydraulic legs for the winter ?
I would appreciate an answer, thank you.
wamafi43 is offline   Reply With Quote
Old 10-12-2015, 09:43 AM   #2
CWSWine's Avatar
When I called about taking weight off the tires using the auto levelers the first question they ask me was if I had electric or hydraulic and I have electric. The answer I got was that good idea to leave them down and take some weight of the tires with them. Now you having hydraulic you may get a difference answer since they are be held by fluid pressure and I could see how that my cause a problems. Best to call Lippert or the place you purchased you RV from
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 10-27-2015, 04:10 PM   #3
I left mine down in front only....it should be ok.....I use tractor in winter that is always outside if u want to operate hydraulic it is better that your oil is warm a bit but if u dont operate there should be no danger it will stay still.
2016 Spartan 1234X Trail-Air Pin Box...thermo windows...12 cu.ft frig....3 seasons patio door
2011 Ford F-250 Super Duty Power Stroke King Ranch 4X4 diesel
Pierre Allard is offline   Reply With Quote
storage, winter
