Old 11-04-2014, 02:11 PM   #1
wicked1's Avatar
Winterize go Question? Anyone put Antifreeze in your Hot Water Heater
My friend always does it but I drained mine and there is still some water in the bottom.
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 11-04-2014, 02:19 PM   #2
ColoradoRick's Avatar
Yikes, NO...no need to but make sure you have the bypass lines switched for winterization. (The small amount in the bottom of the tank will freeze but it'll be fine...the problem is when water freezes and expands but there's no room to expand so breaks whatever is holding it....I've seen it break copper pipes so our PVC pipes don't stand a chance.)
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
6-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 11-04-2014, 02:36 PM   #3
Fulltime family RVer
I feel like I've read that there can be a chemical reaction between the water heater interior and RV antifreeze. Don't know if I'm making that up, if I read it from a credible source, or anything in between.
I think OldCoot fashioned up an attachment for his shop vac to such that last but and any anode debris out. But generally speaking, as long as you dump it out- the water has somewhere to expand to when it freezes and it's not an issue.
Old 11-04-2014, 02:59 PM   #4
TURBS's Avatar
Drain it and forget it!
No antifreeze!
Turbs
Old 11-04-2014, 03:13 PM   #5
Hot water tank
Leave the drain plug out over the winter. that allows for the extra water to exit.
wolfe4656 is offline   Reply With Quote
Old 11-04-2014, 03:26 PM   #6
WFD
Thats exactly why they put bypass valves in place....so you don't fill your hot water tank with 6 gal or more of antifreeze....to do so would be a total waste, and you may not be able to drain the antifreeze out as easily as you can flush it out of your lines.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 11-04-2014, 06:27 PM   #7
wicked1's Avatar
I drained it and left anode out no antifreeze but tiny water in the bottom can evaporate before winter we are good.
Old 11-04-2014, 06:31 PM   #8
Ford Idaho's Avatar
If you are going to leave the rod out stuff a paper towel in the hole to keep bugs from crawling inside for the winter.
Old 11-04-2014, 06:34 PM   #9
wicked1's Avatar
Putting a nylon plug in just for winter
Old 11-12-2014, 10:34 PM   #10
Platokidd's Avatar
Never, flush , bypass and drain.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
antifreeze, heater, hot water, water, water heater, winter, winterize
