Old 10-18-2012, 07:49 PM   #1
dgiturbo's Avatar
Winterized my Tracer
OK, first time doing this, so hope I got it right.
I followed Prime Time's online guide to a T, using the 25psi air compressor method. As I had to unscrew a panel to put my water heater in bypass mode, once I was done blowing air through the lines, I put the heater back in regular use mode before replacing the panel, so as not to have to take off the panel again in the Spring. (I think next time I will add some type of hinge and clasp). Also poured good quantities of RV antifreeze in all the drains. By the way, I used threading Teflon tape when I replaced the water heater drain plug. Is that OK?
Gave everything a good cleaning, and as it will be stored inside a barn, I placed a few packets of Fresh Cab Rodent repellent in the kitchen area, and hung up a Damp Rid in the bathroom.
Had some extra energy so I washed the outside, and used Eagle's Wax as you Dry spray wax. (Washing on a ladder is an adventure itself)
Thought if I missed anything or an easier way?
Thanks.
2013 Tracer 230FBS - Traded for
2015 Crusader 335BHS Yeah baby..
dgiturbo is offline   Reply With Quote
Old 10-18-2012, 08:25 PM   #2
TURBS's Avatar
I see you didn't say you drained the low point drains ?
if you have an outside shower did you blow it out as well ?
did you remove water filter (if it has one) ?
TURBS
Old 10-19-2012, 05:53 PM   #3
The Teflon tape is fine. I personally leave my hot water drain open all winter...and I leave it in by pass...I too have to remove a panel to get to the valves...I just left the panel off and will replace it in the spring..
Even though I blew out my lines, I still use he antifreeze for extra protection. Took me 5 gallons total including the drain traps..at 3 bucks a gallon not a bad investment for 15 bucks.
I agree , make sure u had ur low point drains open to completely drain the lines...I also open and leave open my drain valve for my fresh water tank..
2015 Dodge 2500 Big Horn 4x4 6.4 HEMI
2015 Grand Designs Reflections 323 BHS
Reese 16K Quick Slide with Factory Rail Kit Option
kozzy is offline   Reply With Quote
Old 10-24-2012, 08:33 PM   #4
dgiturbo's Avatar
Low point valves were drained, external shower and BTF were also blown out. Teflon tape it is.
Thanks all..
Waiting for April now.
Old 10-29-2012, 05:10 PM   #5
Commercial Member
dgiturbo - were the instructions clear and complete? Your feedback on them is appreciated.
PTM
RV Guy is offline   Reply With Quote
Old 11-04-2012, 05:34 PM   #6
dgiturbo's Avatar
Yes. The online instructions were a gem. A model specific link to accessing the heater bypass valves would be nice, though I am sure cost prohibitive.
So far great product!!
Old 12-09-2012, 12:28 PM   #7
mdalb20's Avatar
Sorry for the late reply. I have the 2012 and I pump the solution through. I always did it with my boat and never had a problem. I agree on the model specific instructions on the hot water heater but i figured it out.
Love my 2012 230FBS but of course now looking for the next larger one! LOL
mdalb20 is offline   Reply With Quote
Old 01-02-2013, 01:49 PM   #8
SibeTribe's Avatar
Where did you find Prime time instructions for winterizing? I have just been on the website and can't find it.
Sue & Sibes
2002 Ford Expedition XL
2012 Tracer 2700 RES Touring Edition
4 Trips 70 nights
SibeTribe is offline   Reply With Quote
Old 01-02-2013, 05:35 PM   #9
mdalb20's Avatar
The instructions I had were in the manual but again they were not the clearest.
Old 01-03-2013, 04:59 AM   #10
Commercial Member
sibe - there aren't any directions posted on the web site - only how to operate your by pass valves. There are some generic directions in the owner's manual.
However, we have some detailed directions that we can forward you if you contact rstickel@forestriverinc.com. We are in production of a video to help you winterize and we can forward you the audio script. It will be very helpful.
PTM
