Old 11-28-2011, 09:13 AM   #1
Winterizing
Last year I just blew the lines out with an air compressor, but this year I'm thinking about shooting pink antifreeze through all the lines. Just have one dumb question. Where is the water pump located on a Lacrosse 296 and how do you access it?
phone man is offline   Reply With Quote
Old 11-28-2011, 01:20 PM   #2
Notuck's Avatar
Just did mine today. The water pump is in the bathroom below the sink. When you open the cabinet door there is a cover with four screws in it at the bottom. Remove the screws and you will find two valves, one to shut off the fresh water line and another to open the antifreeze pickup line. The hose may be tucked behind the pump if you dont see it at first. The water heater bypass is behind a cover under the kitchen sink that I have found it easier to remove to get to the valves.
Notuck is offline   Reply With Quote
