Old 08-22-2016, 03:28 PM   #1
Winterizing 28RL
My 28RL has a winterizing station in the storage compartment. I know about the water heater bypass. However, I am not sure about the other switch. Do I switch to winterizing mode and stick the short hose in a jug of RV antifreeze ....then use the pump to fill the system? How many gallons of antifreeze?
Dryfly46 is offline   Reply With Quote
Old 08-22-2016, 03:59 PM   #2
Pickin' & Campin'
If by 'switch' you mean valve, then yes you will put it to winterizing mode and suck the antifreeze from the bottle. Saves you from having to put it in the fresh water tank for the pump to be able to push the antifreeze through the system. You don't want to put antifreeze in the fresh tank... it takes forever to flush out in the spring.
As to how many gallons you'll need.... depends on how much plumbing you have (every rig is somewhat different) and whether you blow out the lines first with air. It will take less when blowing out with air because most all of the water will be evacuated from the lines and so when the pink stuff starts coming out, it will not be diluted.
Usually 2-4 gallons is sufficient.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
2017 Ford F-Series SCREW 4x4
Days Camped: '15=22 '16=46 '17=30
winter, winterize
