Old 10-12-2018, 12:06 PM   #1
SPRING IS COMING!!!
Winterizing... Cold snap coming!
We've got temps forecasted to get down to about 33F on Monday here... too close for comfort for me, so I just did a quick winterizing on our Avenger. Let me know if I missed anything, if you don't mind...
Drained the FW tank
  • Drained the water heater tank and put it into Bypass
  • Hooked up air pressure to city water inlet
  • Drained kitchen sink Cold and Hot sides until they blew air
  • Drained bathroom sink Cold and Hot sides until they blew air
  • Drained Shower Cold and Hot sides until they blew air
  • Drained Toilet until it blew air
  • Drained Outdoor Kitchen sink Cold and Hot until it blew air
  • Drained Outdoor Shower Cold and Hot until it blew air
  • Drained Low Point Drains Cold and Hot until they blew air
  • Took blow gun and purged the FW supply line between FW tank and Water Pump (Opened the valve for the Antifreeze pickup, and blew air into it thereby purging the water from that line--- this supply line exits the FW tank UNDER the tank, so I see no other way of purging this line to keep it from freezing...)
I did not fill the lines with "Pink Stuff" since we are taking it back out again in a week... from what I have read blowing the lines out with air is adequate, and we've only got 2 nights of "near freezing" forecast.
Poured The Pink Stuff into:
  • Kitchen Sink Drain
  • Bathroom Sink Drain
  • Shower Drain
  • Toilet
  • Outdoor Kitchen Sink
Then I drained the Grey and Black tanks and made sure they did not have water in them.
We've got one more camping weekend planned, and then I think I'll do the final winterizing for the winter, including filling the plumbing system with Pink.
Did I miss anything? It was really easy to do, and took only about 30 minutes.
BriaBeck is offline   Reply With Quote
Old 10-12-2018, 12:16 PM   #2
Prime Member
  • Shower Drain
  • Toilet
That should be sufficient for some brief sub-freezing temps. Anything longer, you should really pump in the pink stuff.
Don't forget to get the water out of the line that runs from your FW tank to the pump.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is online now   Reply With Quote
Old 10-12-2018, 12:21 PM   #3
SPRING IS COMING!!!
I think I was editing while you were posting
I purged the supply line going from the FW tank to the pump by opening the antifreeze pickup valve and taking a blow gun, and putting air to the antifreeze pickup line. That should have purged that line, and I think there was also air going through the pump as well, I could see air flowing through the supply line screen filter that is attached to the pump.
Old 10-12-2018, 02:12 PM   #4
fonzie's Avatar
If you have black tank flush, maybe just blow air to clear water in it.....
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 10-12-2018, 02:43 PM   #5
Just as confused as you
Scrapper's Avatar
We've been at our camper since Tuesday. Nighttime temps have been down to 28* and 30* on 2 nights with daytime temps around 39* to 46*. Windchill yesterday was 32* to 36*. I don't know how long the temperature was below freezing but I didn't drain the supply hose and it has been fine. The campground closes for the season on Sunday. I wouldn't worry about 2 or 3 hours at 32*.
Richard & Jill
Camping since 1989, seasonal since 2000
Scrapper is online now   Reply With Quote
Old 10-13-2018, 02:19 PM   #6
mads
These posts about low temps got me worried so I bought an indoor/outdoor wireless temp guage ($12) with hi low readings and placed the outside one near the water pump. That way I can truly determine what is happening.
Turns out the temp is holding at least 10 degrees above the outside temp so no worries. I recommend doing the same if you are worried.
Mads Ledet
madsledet is offline   Reply With Quote
Old 10-13-2018, 03:01 PM   #7
This subject keeps coming up and there are two schools of thought. You have the blow it out people and the antifreeze people. I just blow mine out and put antifreeze in traps. If there is no water in the lines after blowing them out there is nothing to freeze. I guess its just a preference thing. Good luck and safe travels to all.
KNMIB is offline   Reply With Quote
Old 10-13-2018, 03:13 PM   #8
2X KNMIB, never had a problem.
KQ2N is offline   Reply With Quote
Old 10-13-2018, 09:19 PM   #9
One of our camping neighbors said he puts vegetable oil in the toilet to keep the toilet seal from sticking. Does anyone else do that?
Rikki73 is offline   Reply With Quote
Old 10-13-2018, 09:28 PM   #10
HerveVR's Avatar
Did you turned Off the electric element of the Water Heater?
To be sure...
2012 Lexington 265DS
HerveVR is offline   Reply With Quote
winter
