Old 10-28-2012, 05:39 PM   #11
Has any one had trouble with geting the 12 volt pump to prime on a 2013 sierra 365 saq. Trying to winterize also says to close valve A and open valve B along with the by pass for the hot water heater. I found the by pass valve but do not see the others. Are they hidden some where?"Also I did open the valve for the suction line that goes in the antifreeze bottle. Sure is different than our old dutchman that I put a t on the line at the pump turn a couple valves at the water heater hour later I was done. Any thoughts would sure be a big help. Thanks Pburg Jeff
pburgjeff is offline   Reply With Quote
Old 10-28-2012, 09:21 PM   #12
At the valve for the sustion tube for the antifreez, you should have a valve to shut off the supply from your fresh water tank, make sure that is closed.
On your hot water tank, you need to open the bypass valve, and close 2 valves that lead to your hot water tank.
Well, that is assuming you have a true bypass kit installed. I am sure there might be different varations out there.
2015 Dodge 2500 Big Horn 4x4 6.4 HEMI
2015 Grand Designs Reflections 323 BHS
Reese 16K Quick Slide with Factory Rail Kit Option
kozzy is offline   Reply With Quote
Old 10-28-2012, 09:40 PM   #13
phat phrog stunt crew
you folks in the northeast may be living in your campers in a day or so. might be the only things wiith heat. good luck to you and let us know how you make out.
dwaynerz is offline   Reply With Quote
Old 10-28-2012, 09:45 PM   #14
rracer5's Avatar
Got it hitched up to the truck for extra weight already......bring it on !!!!
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 10-28-2012, 10:18 PM   #15
mine is at the dealer getting some work done...if it flys away, they owe me a new one, hell its still under warantee right???
Old 10-28-2012, 10:41 PM   #16
RockyMtnHigh's Avatar
Originally Posted by portliz View Post
We have been told to crack the vents slightly to avoid condensation. Is this correct? We also put in some stuff - I think it is called dri rid to capture any moisture.
I keep our vents all sealed up, but then use a Dri-Z dehumidifier over the winter. Seems to do a good job of keeping the humidity down. We have a number of freeze/thaw cycles each winter due to our Chinook winds, so moisture is a concern. Never had any issues with mold/mildew.
2009 Roo 21RS
2010 GMC Sierra 1500 w/ tow pkg
Nights camped in 2014:29 | 2013:33 | 2012:32 | 2011:33 | 2010:30
RockyMtnHigh is offline   Reply With Quote
Old 10-29-2012, 04:42 PM   #17
what do those of you with water filters do? fill with filter in place? remove filter and fill sight glass with antifreeze?
Old 10-29-2012, 06:11 PM   #18
i dont have a water filter system, but I know you want to remove the filter. Most of the systems I have seen have a bypass, I would removed the housing and turn on the bypass, dont have to worry about it cracking then.If you dont have a bypass, might want to think about making one up.
Old 10-29-2012, 06:13 PM   #19
Ret E-9 Anchor-clanker
donanddona's Avatar
Yes you have to remove the filter. After I have everything inside done it's one of the last things (filter removed and canister removed) I complete outside. don't forget the handheld outside to....
donanddona is offline   Reply With Quote
Old 10-29-2012, 06:36 PM   #20
winterize
I blow out the lines with a compressor set at 30PSI, run all faucets till just air, also blow out the drain lines to empty traps. Remove the water filter cartidge, and drain grey and black tanks good. I can get to my blade valves to clean and put a little vaseline on gakets, close em up. Then use the 12 volt pump to run RV antifreeze in till all faucets hot & cold run pink. Put about 1 1/2" in toilet with valve closed.pour about 1/2 gallon down each drain to fill traps and get some to the tank valves. Close all vents $ windows, place a couple of the "Damp Rid" containers in rig with about 8 "Bounce" Dryer sheet spread through out. Make sure no liquids left in rig, No food, fridge doors open. Pull battery an charge it full then store in garage. I use a ADCO camper cover, on my second one in 8 years and so far everything has survived GREAT. Bounce sheets smeel great ans supposed to help keep out critters. Come spring I open it up and use the 1/2 cup of Chlorine Bleach to 30 gallons of water into Fresh Water tank, run it through system till clear water, chlorine smell at each faucet. leave it for 24 hrs. flush it with fresh water install new filter cartidge, and redy to go.
TnCowboy is offline   Reply With Quote
