Old 06-29-2013, 06:16 AM   #1
X-chock on Lacrosse 318bhs
Anyone recommend the X-chock on 2013 Lacrosse 318bhs? Will it even fit given the distance between axles?
Trying to help with stabilization and have seen good reviews on X-chock.
Thanks.
davidzapp is offline   Reply With Quote
Old 06-29-2013, 06:26 AM   #2
TTNewbees's Avatar
Yes, helps a little. You need the x-tended x chock.
Mike
2012 Lacrosse 303RK
2012 F250 6.7 diesel
TTNewbees is offline   Reply With Quote
Old 06-29-2013, 09:54 AM   #3
We found it helped very little.
Laura is offline   Reply With Quote
Old 06-29-2013, 10:33 AM   #4
I use only one, and I can't imagine any 2 wheels being closer than mine. I think that it made a WORLD of difference on our camper. I don't even think I need 2 of them. Mine is the standard BAL X CHOCK. Randy
Old 06-29-2013, 10:48 AM   #5
I think you would be pleasantly surprised by using a 2nd one.
Old 06-29-2013, 11:31 AM   #6
I use the x tended version on my 318. Love them. They do make a difference and work great. Have to special order the, I think at most places.
I would use regular chicks while u level your unit, once your set with that, put the x chocks in, you won't move..
2015 Dodge 2500 Big Horn 4x4 6.4 HEMI
2015 Grand Designs Reflections 323 BHS
Reese 16K Quick Slide with Factory Rail Kit Option
kozzy is offline   Reply With Quote
Old 06-29-2013, 03:57 PM   #7
Love my x tended x chocks on my 318.
Joe & Anna & the boys
2012 Toyota Tundre 5.7
2013 Prime Time Lacrosse 318 BHS
2013 Night Camping 41
kempoman is offline   Reply With Quote
Old 06-29-2013, 04:27 PM   #8
Denver, CO
garbonz's Avatar
rotochoks come with specific wedges for any spacing. they are awesome, very fast to deploy and very effective.
2017 Fuse 23T
Old 06-30-2013, 07:56 AM   #9
rracer5's Avatar
X-4 on the x-tended x-chocks. I use 2 and have very little movement. I also put quite a bit of pressure on my stabilizer jacks. Keeping the stabilizer jacks close (not too extended) to the frame will also help. Build up under the jacks with blocks. This will minimize any flex from the jacks.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
