Old 04-08-2011, 10:50 PM   #21
sherdep's Avatar
Hey RhoZeta,
not sure if you got the instructions with your X Chock kit or not but it tells you in the instructions to detach the tow vehicle and level the trailer prior to installing the X Chock and remove X Chock before attaching the TT to the TV
Might be worth it for you to buy a set of wheel chock's and then install the X Chock's after your trailer is setup if you are a incline / grade
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 04-09-2011, 10:13 AM   #22
prof_fate's Avatar
Doesn't that sorta defeat the purpose of using them? I ordered a pair to stabilize while camping but mainly for safety when unhitching - read a scary story on this forum where a fellow used a regular chock and it slipped (as i've seen happen on other trailers) and the tougue swung when it came off the ball and nearly pinned the guy.
the 'level' the spot the more danger I think there is as no piece of ground is perfectly level and removing the tounge from the ball may allow the trailer to 'settle' a bit. I've been surprised a few times. Perhaps a much heavier trailer stays put more than lighter ones?
Originally Posted by sherdep View Post
Hey RhoZeta,
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
Old 04-12-2011, 08:02 PM   #23
grhodes50's Avatar
As far as I always understood it, the X-chocks are to help stabilizer the trailer while camping. That's why I purchased mine.
I do use wheel chocks when hooking/unhooking the trailer and while parked at the house. I haven't had any problem with them.
Gary & Trish
2018 Nights Camped - 5
axle
