Old 06-23-2015, 05:28 PM   #1
Yamaha ef2400ishc
My single honda Eu2000i will (obviously) not power my ac unit on my tracer air 250. I was looking at the ef2400ishc by yamaha as they claim it will run most 13,500btu air conditioners. Then I'd sell my honda and recoup some of the cost. Thing is, once you put oil and gas in a generator, you can't return it so if it doesn't fire up my ac I'm out 1200 bucks.
Sooo, that being said, does anyone have one of these running their ac on a tracer successfully? I know it won't run anything else but that's OK, I just need it to cool down the camper for an hour or two in the evening and maybe at midday. Let me know, thanks!
coolzzy is offline   Reply With Quote
Old 06-23-2015, 06:09 PM   #2
Georgia Frog Rally 2018
aceinspp's Avatar
Well the bad news is you need the 2nd Honda Gen the EU 2000i companion to run the air. I Bought the Boliy 3600Si unit that can run the 13,500 air and it came with battery start and cost less than the 2 Honda's. About the same DB rating as Honda. The newer models are now equip to add an optional fuel tank of 6 gal or more. Will run 8 to 12 hrs with air on. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
Old 06-23-2015, 06:16 PM   #3
The companion is 1100 bucks plus the expensive parallel kit. If I buy the single yamaha then I can sell my honda and end up only 600 bucks out of pocket. It weighs 75 pounds and is as quiet as the honda. Every generator I've seen that someone claims to be "about the same" as a honda has clearly never heard a honda for side by side comparison.
I've heard the yamaha and it is the same if not quieter Than my Eu2000i.
Old 06-23-2015, 06:18 PM   #4
jtstromsburg's Avatar
Have a friend that has the Yamaha 2400 & he wasn't able to run his 13.5k btu. That said, I'm 99% sure that with a hard start cap added to the AC, it's do it. If I were in the market for a genny, and could manage the weight, if definitely spring for a larger one, but that's me. The idea of two Honda's is great too, but costly I realize.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 06-23-2015, 06:23 PM   #5
fonzie's Avatar
See post #14
What size of generator is neeed? what kind?
Fonzie
Old 06-25-2015, 04:31 PM   #6
irishrv's Avatar
My crusader 295rst has the quiet cool 15000btu dometic. I was able to start and run it with my Yamaha 2400is about 6 years old but low hours. Will every ac work? Probably not. My 2400is also ran the 13.5 ac in my last trailer a 2007 cougar.
2014 295rst champ te
2009 2500hd GMC d/a
2014 295rst TE Champagne
09 GMC 2500HD D/A
irishrv is offline   Reply With Quote
Old 06-25-2015, 04:50 PM   #7
MtnGuy's Avatar
I don't have a Tracer, but do have an Yamaha EF2400is. I have run my 13,500 BTU AC at 3500' elevation without a problem. But.......I take some precautions.
I make sure the fridge and water heater are on gas only. Also make sure the freezer defrost strip is off, if your fridge has 1.
I will let the genny run a bit to charge the batteries to hopefully lessen the load there. I will also let the AC fan get up to speed before starting the AC compressor.
I have heard that a hard-start capacitor in the AC helps with the load, but I haven't had a problem starting and running the AC off of the EF2400is with the capacitor that came with my AC.
Old 06-25-2015, 04:54 PM   #8
Flybob's Avatar
EU2000i Companion $1049 Parallel Cable set $49.
If you don't need AC, you can bring just one. Any generator that can run you AC as a single unit will be heavy and difficult to move around.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-25-2015, 04:56 PM   #9
I didn't want to take the risk, I bought a champion 3100 inverter generator locally for 850. It won't be quite as quiet as my honda or the yamaha but it will run my ac and TV at the same time so we'll see how that works out. Probably keep my honda jut in case, it would be hard to replace for what I bought it for.
Old 06-25-2015, 04:57 PM   #10
WolfWhistle's Avatar
IMO almost every AC unit needs a "start assist" (or hard start) kit added. Especially if you see the lights flicker when the compressor "hits". Some may already have them. FR should specify that Dometic (for example) include the very inexpensive kit all the time every time.
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
