06-05-2015, 08:46 AM
#681
Originally Posted by Herk7769
But the pedestals are shared so someone could need an adapter.
That is true they are shared by 2 sites but both have a 30 and 50 for each side. At least that was in the 200's # spaces as I quoted. Each also has there own spigot and sewer line.... As far as the person who asked about the surports for the sewer line, I found 1 will work with some added boards. Remember it connections are like 6 to 8" above ground level at the pedestal.....
Coachmen M/H
Concord
2018 / 300 DSC
06-05-2015, 09:05 AM
#682
Originally Posted by gljurczyk
That is true they are shared by 2 sites but both have a 30 and 50 for each side. At least that was in the 200's # spaces as I quoted. Each also has there own spigot and sewer line.... As far as the person who asked about the supports for the sewer line, I found 1 will work with some added boards. Remember it connections are like 6 to 8" above ground level at the pedestal.....
Thanks, I was only parked in the 200 area 1 time and I forgot what the pedestal looked like. Advice regards adapters is still valid though for most.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
06-05-2015, 09:56 AM
#683
After looking at the fairground map what gate should we arrive at? Main Gate #1?
06-05-2015, 10:07 AM
#684
I believe last year it was gate #2. I just followed the signs once I got close, they had it well marked.
06-05-2015, 10:08 AM
#685
I went in the "open" gate!
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "9 nights"
#686
What time do they start moving people in?
06-05-2015, 01:32 PM
#687
When you get there
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
06-05-2015, 01:36 PM
#688
5 a.m.?
06-05-2015, 02:48 PM
#689
Not sure about 5 am but we rolled in Fri. about 1pm maybe the coffee drinkers will be up.
and I think I see my camper too
2003 Duramax
2010 Blue Ridge
1 DW
1 mutt
on occasion 1 DD
06-05-2015, 02:56 PM
#690
Enter at gate #2 Iggy, look for a sign like this.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
06-05-2015, 05:04 PM
#691
Originally Posted by Oakman
Thank you Oakman
06-06-2015, 10:38 AM
#692
Attendees of the Goshen rally might want to consider having business cards made up with their contact information. You are going to meet a lot of fellow FROGs and passing out business cards is an easy way to share personal contact information with the new friends you make at the rally. Some folks put pictures of their rigs or photos of themselves on the cards. It’s quite easy to make business cards on your home computer or you can have it done professionally. Just something to consider.
Bob and Joyce
ATU Local 788
06-06-2015, 10:41 AM
#693
X2, I had the same idea and already done!!!
Avery.com has a great program for this (design your own). All you have to do is buy the card stock paper.
2014 Prime Time Sanibel 3250
06-06-2015, 11:27 AM
#694
I don't want to read 70 pages of posts and if this has been covered before ,I apologize. Are sites assigned per registration number or upon arrival? Is there an attempt to position similar types of RV's together? Is there any advantage to arriving a day or two early? I for one would like to be with a group of Berkshires to share thoughts and ideas.
Dan
2015 Entegra Anthem 450HP-1250ft lbs of torque
2015 Jeep Grand Cherokee
Roadmaster Falcon 2 All Terrain
SMI Air Force 1
06-06-2015, 11:34 AM
#695
I believe they said earlier there is no advantage to early arrivals. They essentially are playing a game of Tetris here but I believe they try to put brands together ie primetime together, palomino together. I believe they did an r pod village and a section for the phat phrog crew as well.
2014 Sabre 34REQS-6
06-06-2015, 02:44 PM
#696
Those are great supports. However, I got in a bind at a couple of campsites where I had to go over railroad ties.
Here is another solution. Yeah I know it is pricey but you only buy this once and it does thing you can't dream of doing with the cameo (like make 90º turns)
Also, I had problems with my Camco falling over at times...that could have been operator error though
http://smile.amazon.com/Lippert-Comp...=ATVPDKIKX0DER
Since it is now owned by Lippert, maybe they will have a Rally special on the Flow Down (if they do, I will buy another one)
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
06-06-2015, 02:49 PM
#697
There are certain brands that will park together: The Cardinal, Columbus, & Cedar Creek "Owners Groups"
Of course the R-Pod "Village" (AWESOME they even elect a "Mayor"
Other than that, you are parked "Hobo" style (the folks you are in line with will be your Rally neighbors )
Provisions are made so that if you arrive early, you will not have to move once the rally starts
06-06-2015, 02:52 PM
#698
Originally Posted by HSVBamaBob
...Here is another solution. Yeah I know it is pricey but you only buy this once and it does thing you can't dream of doing with the cameo (like make 90º turns)...
Be a cold day in you know where when I throw $80 away to prop up a sewer hose when it can lay on the ground for free. In all my years of camping, have never seen the need to support a sewer hose.
06-06-2015, 02:55 PM
#699
That's a GOOD idea!
I have used this service before they are reasonable (and at one time I think they did the printing for free if you let them advertise on the back of the card)
http://www.vistaprint.com/category/b...ds&xnav=TopNav
06-06-2015, 03:46 PM
#700
For the most part you are parked depending on your registration
"First come first served"
Your spot is more or less pre determined before you arrive.
There are "better" spots then others and they go first, again it's in the order you signed up. -ish
TURBS
2011 32bhok Sabre
