Old 06-04-2015, 09:06 AM   #661
Herk7769's Avatar
Originally Posted by rockfarmer View Post
one more thing that you might want to bring is a "Y" adapter for the water line in case two units need to hook onto the same water tap.
ALL full hookup sites share water and power pedestal but not sewer. BRING Sewer supports as most are NOT at ground level and you will have a big "U" in your hose if you don't support it.
Water and 30 amp only sites (about 600 sites) do not need Ys but will need adapters for 50 amp coaches.
HAM CALLSIGN - KC3FFW
Old 06-04-2015, 09:33 AM   #662
tmmar's Avatar
Originally Posted by Herk7769 View Post
You won't be able to run both ACs at the same time on 30 amps. You will need to close off the bedroom during the awake time and swap ACs at night.
I could be wrong, but I don't recall many 50 amp sites (even the full hookup ones). BRING POWER ADAPTERS. 30 amp campers should be prepared to use a 50 if there is one and you get put there.
I am bringing one of these Sears Local Ad at LANGHORNE, PA : Find Deals on all Holiday Gifts
BRASS ONLY as the plastic ones break due to the hose weight
You need to be careful when using brass fittings. You have to make sure that they have a low lead content or the lead can leach into the water supply, which is not a good thing.
Tom and Margaret
2014 Berkshire 390bh-60
Old 06-04-2015, 10:26 AM   #663
Iggy's Avatar
Here is a map of the Fairgrounds that show the campsites and what they have.
Wow this is a big fairgrounds.
2012 Georgetown XL - 378TS 63K + miles
Old 06-04-2015, 10:26 AM   #664
rracer5's Avatar
How about some of us each "make" a hose pigtail out of an older 3/4" water hose long enough to reach from the spigot to to the ground? That way all of our Y's will be on the ground and we won't have to worry about how much weight that first Y on the spigot will hold.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 06-04-2015, 10:34 AM   #665
Witch Doctor's Avatar
They do have 30 amp and 50 amp sites, I know that all the 200 # section they had both in the panel. I'm almost positive on that, I think I used a 50 with a 30 amp dogbone last year..... It even shows on Iggys map the 50 amp sites.
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 06-04-2015, 02:37 PM   #666
BamaBob's Avatar
Yeah it is! And here is a Aerial photo taken at the rally last year -- this was with ~500 Rigs -- imagine what another 200 or so rigs are gonna add to that!
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
BamaBob is offline   Reply With Quote
Old 06-04-2015, 02:38 PM   #667
TURBS's Avatar
I see mine!
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "9 nights"
Old 06-04-2015, 02:50 PM   #668
BamaBob's Avatar
Originally Posted by TURBS View Post
I see mine!
TURBS
2011 32bhok Sabre
LOL...there were 2 or 3 aerial shots taken and I thought folks would like the Phrog pond view
Old 06-04-2015, 05:36 PM   #669
I saw mine, or at least the top of the truck
dblr is offline   Reply With Quote
Old 06-04-2015, 08:12 PM   #670
Assistant TP Supervisor
B and B's Avatar
I see mine!
TURBS
2011 32bhok Sabre
I can see mine two! And he strictly stick 5er sticks out like a sore thumb beside Herk's. I even see green bottles in the beer tasting magic mirror...
frog
