Old 08-21-2017, 02:57 PM   #1
At the rally
I brought a battery watering system at the rally and I'm having trouble with it. Did anyone else in here buy one? I know I'm not the sharpest tool in the bag. Oh well I called both numbers on there card, maybe they will respond
spock123 is offline   Reply With Quote
Old 08-21-2017, 06:46 PM   #2
florabama's Avatar
No, I didn't get one but wish you well in figuring it out. I've heard this is the way to go; especially if you have 6v batteries.
2016 Ram 3500HD 6.7L CTD 4x4 CCSB
2017 CC 34RL2 Hathaway Edition
Andersen Ultimate 5th Wheel Hitch
Nights Camped: 2017=61
Nights Camped: 2018=25
Nights Camped: 2019=12 | Booked=6
florabama is offline   Reply With Quote
Old 08-24-2017, 06:35 PM   #3
ernest917's Avatar
I bought one and went straight back to my coach and had it installed in abt 10 mins.... I have 4 - 6v golf cart batteries... Actually pretty simple install - pull old caps off batteries and store in a zip-loc bag.... Install one of the fittings into each of the cell openings (push down until u hear it click - means it's locked in place)... Now take clear tubing included and cut to length so that you can connect each cell together... (I did both rear batteries and ran the tubing L to R).... Do the same thing on the front two batteries. Now connect the ends of these tubes together using the "T" fitting to connect them together and then connect the free end of the "T" to the portion of the tubing that has the connector attached to it..... Take the little plugs included and cap off the ends of the tubing left open..... THAT'S IT !!!!! YOU'RE DONE !!!!
ernest917 is offline   Reply With Quote
Old 08-24-2017, 07:52 PM   #4
Yea I finally got mine installed. I installed them on four batteries I had laying around and then installed them on my Trojans
Old 08-24-2017, 07:55 PM   #5
ernest917's Avatar
Good..... I really like mine.... Don't even have to slide my batteries out to check water
levels..... Just hook up squeeze bulb, drop free end into gal of distilled water and pump away....
