Old 07-11-2013, 09:10 AM   #1
Now Camping Year-Round!!
WannaBcamping's Avatar
Getting service to RV by FR Techs
Both our A/C's don't work, outside kitchen taps need to be switched so that the hot is on the left and one burner inside on cooktop won't start unless manually lit. The last two repairs I am sure that the FR Techs can handle in Goshen. But what about my A/C? Any idea if I can expect them to fix this there? I don't have enough time between now and August 4 to drop our unit at our dealer and reasonably expect them to fix it (which I believe may need new units) and still have the unit back in time to go to Goshen.
What kinds of repairs do they do in Goshen and any idea if they can fix our A/C???
Thanks in advance,
Cathy
Cathy & Fraser - Ontario, Canada
2017 Rockwood ML 2507S
2013 Columbus 325RL -parked in Florida
2011 Ford F250 Super Duty Diesel King Ranch
2011 Rockwood Roo 21RS
2009 Wildcat 29RLBS
WannaBcamping is offline   Reply With Quote
Old 07-11-2013, 09:37 AM   #2
Herk7769's Avatar
I suppose it depends on what is wrong with your air conditioner(s).
Am I right that BOTH your air conditioners are acting up?
HAM CALLSIGN - KC3FFW
Old 07-11-2013, 09:43 AM   #3
TURBS's Avatar
Have we checked the breakers ?
Turbs
Old 07-11-2013, 10:08 AM   #4
There is power, they both turn on and appear to function at a distant glance. We were away this past weekend. It was 78 degrees outside and inside the RV it heated up to 89 degrees. We turned the A/C on for the first time ever since getting it. The main A/C in the LR works but inefficiently as after 5 hours on full blast it went down to 81. The bedroom unit keeps cycling on and off frequently and doesn't cool. It is more like a big roof fan-a very noisy one at that which is a common complaint with these.
And yes, hubby has checked the brakers. Unfortunately that is not the problem.
2009 Wildcat 29RLBS
Old 07-11-2013, 10:24 AM   #5
Changing the hot & cold water lines is an easy fix, just shut the pump & city water supply off, remove the faucet assy and switch the lines. Usually doesn't even require a wrench/pliers.
Old 07-11-2013, 10:42 AM   #6
Phat Phrog
RVChick's Avatar
Our furnace has not worked since we bought our rig and I am requesting it to be repaired in Goshen. We had a mobile tech come out but they couldn't tell what was wrong! I hope they can fix it in Goshen too since our dealer is several hundred miles from us! I sure hope Goshen can handle your repairs too! After all....they ARE the experts!
Kenny n Karen
TV: 2007 Chevy Silverado 3500 DRW - named Alice
RV: 2012 XLR Thunderbolt 35x12 - named Thor
RVChick is offline   Reply With Quote
Old 07-11-2013, 10:49 AM   #7
TURBS's Avatar
First I've heard oph this ?
Maybe kenny disconnected sumpin so you snuggle closer on those long winter nights ? Maybe he needs more spoonin?
Old 07-11-2013, 10:53 AM   #8
Phat Phrog
RVChick's Avatar
Well we did....but that didn't help the furnace?....I'm just sayin!
Kenny n Karen
Old 07-11-2013, 12:31 PM   #9
I'd be surprised if you need the furnace in August. Now that doesn't stop anyone from spooning....but I'm guessing it will probably be hot. Guess I'll have to drink a lot of cold bevvies to help cool myself!
2009 Wildcat 29RLBS
Old 07-11-2013, 12:33 PM   #10
TURBS's Avatar
Might I join you ?
We can follow oc around all day and watch him fix everything in the fair grounds.
