Old 05-02-2018, 10:40 AM   #1
Tires
I have tires on my 5th wheel that calls for 110 lb at cold temp. I would to know if going down the road the pressure goes to 115-120 is that to much?
Carl Hargis is offline   Reply With Quote
Old 05-02-2018, 10:47 AM   #2
wmtire's Avatar
No, you should be OK. Tire pressure will increase with temperature increase. Tires are designed with this pressure increase factored in.
That's why you should only normally adjust tire pressures (barring a leak) at cold inflation (which is in the morning, before being driven).
EDIT: This link may help:
https://www.tirerack.com/tires/tiret....jsp?techid=73
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
Old 05-02-2018, 11:05 AM   #3
Thank
Old 05-02-2018, 11:21 AM   #4
How did you determine 110 PSI is the correct cold pressure? Reason I ask is there are MANY opinions on what is the correct pressure. 110 PSI sounds like it may of come off the sidewall. To me, that would be the correct pressure for tires at maximum load. That is not necessarily the correct pressure for your application, but the worst that will happen is a rougher ride and wear in the center of the thread. That's WAAY better than under inflated!
Another approach would be to weigh the trailer to determine the actual load on the tires and look up the correct pressure(s) in a tire load chart. Weighing the trailer will also confirm the rig is within weight limits and setup/loaded correctly.
2017 Riverstone 38FB Legacy
2018 F450
LegacyFB38 is offline   Reply With Quote
tire, tires
