Old 10-17-2017, 02:29 AM   #1
Fulltime family RVer
12v drinking water safe transfer pump?
After spending the last 2 weeks boondocking, I've had an opportunity to fill my water tank a couple of times from a 60 gallon fresh water bladder.
I pumped it in by using the anti-freeze inlet and winterization valve of the camper to suck in from the bladder and then used the outside shower hose to fill into the freshwater tank. It worked but it was sloooooow.
I figure my camper's pump is good for up to about 3 gpm but by the time the water traverses the camper's water system and then gets squeezed down by the outside shower hose- that flow was knocked back by quite a lot.
I started looking at 12v transfer pumps, but I'm having a hard time finding any that are drinking water safe.
What do you use? Did you worry about it being drinking water safe?
Old 10-17-2017, 05:59 AM   #2
Who Dares, Wins
doc73's Avatar
I have seen several people just use another rv water pump as their dedicated transfer pump.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 10-17-2017, 06:09 AM   #3
Just purchase a good hi-flow 12v RV water pump as your transfer pump.
Days Camped: '16=46 '17=30 '18=51 '19=4
Old 10-17-2017, 06:14 AM   #4
That's what I use, a RV pump. I have it rigged to plug into the 7 plug receptacle on the TV with an on/off switch. It pumps into the gravity water feed to the tank in the RV. A cigarette plug on the end of the wiring on the pump works for me. https://www.amazon.ca/Reese-Towpower...9EW5F06QV6A5C2
Hope this works
Pipeman is online now   Reply With Quote
Old 10-17-2017, 06:32 AM   #5
lswartz's Avatar
I use a DW .
Really, she holds the funnel & I dump it in from a 7 gallon water jug. We use just a bit more than 5 gallons a day & filling every other day (or whenever I remember it) covers a long camping trip.
2013 Rockwood Mini Lite 2109S
2010 Toyota Tundra 4WD
lswartz is online now   Reply With Quote
Old 10-17-2017, 12:21 PM   #6
extremebike's Avatar
HI. I rigged up a cheap RV pump and got 1/2 inch to 3/4 garden hose adapters for the inlet and outlet. I use a small 3 A-hr battery with clips to power the pump.
I can pump 30 gallons in about 15 minutes. It's just enough time to get out the chair and start a beer.
regards,
Extremebike
2004 Ford F550 6l Lariat SuperCrew, Fontaine Bed,
Link Systems Air Ride
2011 Sterling 32RL with Michelin XPS tires
extremebike is offline   Reply With Quote
Old 10-17-2017, 12:24 PM   #7
Well crap- yall are telling me to not be so cheap and buy the right tool for the job...
Old 10-17-2017, 12:37 PM   #8
Did you remove the flow restrictions from the outside shower? Found 2 of them in mine, 1 at each end of the hose.
Another possibility is to put in a T and a shut off in the water line on the pressure side of the water pump and run from that into the fresh tank.
DougW is offline   Reply With Quote
Old 10-17-2017, 12:51 PM   #9
DougW I like your idea of the T
Tom & Terri
2012 GMC Yukon
2013 Roockwood Mini Lite
Tomgky is offline   Reply With Quote
Old 10-17-2017, 01:21 PM   #10
Doug,
I plumbed these to the bottom of my low point drains.
They accept a standard garden hose.
If you had something similar you could use the winterization port on the intake side of the pump from the bladder and then from this into your fresh fill port. Utilizing the pump you have and without the restriction of the outside shower.
We often use these connections to wash the camper/kids/pets/rug/etc. Plenty of flow.
pump, water
