MAKE SURE YOU LOOK AT THE GENERATOR'S CONTINUOUS RATING. Most generators numerical identification (Honda 2200, Champion 3100, Predator 2000) are SURGE capacity and not continuous generating capacity. The Honda 2200 is rated for 1700 watts continuous, the Champion 3400 is rated for 3100 watts continuous, etc..etc..)
Surge rating is important but don't be mislead in thinking that the model generator number is the actual continuous rating-IT AIN'T
Personally, I don't think that a Champion 3100 (continuous 2800 watt rating) is sufficient for camping especially if you go to higher altitudes. With 2800 watts, you may have trouble running the air conditioner if your battery is low-my converter can use up to 900 watts and you may not have sufficient residual for other items.
With the champion 3400 (3100 continuous), I can run air conditioner and microwave at same time without worries.
