Old 02-06-2015, 02:40 PM   #1
Kampnnit's Avatar
Battery Charger and Built-in Converter used at the Same Time
Does any one know of a reason why I can not speed up the charging of the batteries by hooking up a battery charger at the same time the built-in converter is supplying power to the batteries too?
I have two batteries and am looking for a faster way to charge them due to the limited amount of time you can run a generator at some national parks. I would like to to use a charger that is capable of 50 amps. I know the converter is much less than that.
Kampnnit is offline   Reply With Quote
Old 02-06-2015, 02:49 PM   #2
Witch Doctor's Avatar
I would not add a second charger, either get a new convertor like 70 amp or just buy the 50 amp and only use that. Look at a progressive 70 amp exact same fit just change the wires over. You probably have a WFCO 50 amp now.
Coachmen M/H
Concord
2018 / 300 DSC
Old 02-06-2015, 03:58 PM   #3
X2. I would highly discourage dual chargers. In conjunction with upgrading your charger, other preferred methods would be to not discharge your batteries as deeply between charges (no more than 50%, but 70-80% is preferable), or increase the size of your battery bank to more adequately fit your daily power usage.
Just curious, but how are you determining state of charge? Have you ever done a power audit?
The more information you provide (battery type, what do you typically run, what genset are you using, etc) the better able we are to help.
rana is offline   Reply With Quote
battery, converter
