12-25-2016, 09:54 PM
Battery Inverter
Can't afford a generator right now, but I am looking at a $200 battery invertor on Amazon. I believe this device will allow me to watch tv, run an electric heater, or plug in small appliances when boondocking. I don't want to use power from the TT batteries. Anybody ever try something like this?
https://www.amazon.com/gp/product/B0...=AY5XLL1NQPR7O
12-25-2016, 10:12 PM
It would be good for items up to 200 watts. ( Link to specs). This would not include such things as a heater, coffee maker, microwave, electric frying pan, or anything like that. It could run a small tv for a short time, or a laptop computer, phone charger, or other small draw things.
It all depends on how you want to use it.
2014 Cedar Creek 36CKTS Explorer
Xantrex Freedom SW3012 inverter/charger
2019 F350 Platinum CC, PSD, 4X4, long box, SRW
Demco Glide Ride pin box
Demco Hijacker UMS 21K hitch
12-26-2016, 12:41 AM
About all that will do is run a TV and recharge electronic devices.
No way will it run an electric heater.
12-26-2016, 01:31 AM
It says it can charge an iPhone 10 times. No way it's going to run an electric heater or anything much more than a phone or tablet.
2011 Traverse LT, 3.6L, FWD
12-28-2016, 10:07 PM
If you can afford $100 more Cabelas has a sale on Champion Generators till Jan 3rd that will everything you want and more
12-28-2016, 11:32 PM
That Champion generator for $300, is not appropriate for campground usage. Too Loud!
I know cause I own one.
It is fine for dispersed or motor race camping and home backup power.
12-29-2016, 12:42 AM
The Champion 2000 inverter for $649.99 sounds like a good deal, and is comparable to a Honda 2000 for noise. I have the 3100 watt version and it has been 100% reliable, the same as the 2000 Watt Honda it replaced.
12-29-2016, 11:17 AM
That's expensive for that model.
You can find better prices than that.
12-29-2016, 10:10 PM
You are correct sir. $546 right now at Camping World. (Link)
Likely cheaper elsewhere too.
12-29-2016, 10:44 PM
Dan, so if we are only doing "Hot" camping in the desert, which is the only time we would need the 4000 (we currently have a 2000) do you think this would be a good buy? You say it's loud??? the ad says "With a noise level of 68db, it’s quiet – only 8db above normal conversation." so I was wondering how it sounded.
or besides Cabela's having their sale, right now we could get the Predator 4000. Do you know anything about the Predator??
12-30-2016, 01:40 AM
There is NO such thing as a "quiet" open frame generator.
Decibel ratings are logarithmic. So a difference of 8 decibels is HUGE. That's sales BS that 68db is quiet.
I own a Champion 3500/4000 with the 68db rating and I also own a Honda 2000i with a 53-58db rating.
With the Champion, you have to yell to converse with someone standing next to you.
But for desert camping, either generator would work, depending on the size of your a/c. 13.5k should work, not sure with a 15k.
The Champion is a tried and true generator with great customer support. Don't think the Predator can make the same claim.
12-30-2016, 02:23 AM
At 90 decibels you start to do hearing damage . I have the 2000 watt inverter Champion that can be paired to make 4000 watts. They have a 53-58db rating also. weights in at less than 50 lb so easy to move. It is very quiet and sips the gas at a very slow rate for the power it makes. If you look around you can buy one at $450.00.
Hope This Helps Tim
