Old 03-01-2019, 01:09 AM   #1
SailorSam20500's Avatar
Champion Gen model question
I'm looking at Homeless Despots website. They have 2 2000 watt Champion Generators available. Model 100565 for $399 and model 100306 at $549. As far as I can tell, the difference between them is that the high price gets a fancy display of power output, fuel level, and remaining run time. Do you think the fancy display is really worth $150? Note that for $399, you may not get an oil funnel.
Al
Save the Earth. Itís the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2018 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
Old 03-01-2019, 12:10 PM   #2
Trailer Park Supervisor
NJKris's Avatar
not worth it unless you plan to use them constantly. BTW, my 350 dollar model came with the oil filter and other stuff. Look around for the parallel connector, prices vary wildly, i paid 38 bucks for mine i think. Also, don't pay more than 10 bucks for the 'dust cover' if you want that too.
NJKris is offline   Reply With Quote
Old 03-01-2019, 12:16 PM   #3
SPRING IS COMING!!!
I like all the fancy gadgets, but I don't think that the $150 premium is worth it in this case either.
BriaBeck is offline   Reply With Quote
Old 03-01-2019, 12:18 PM   #4
They appear to be the same except for the fancy schmancy stuff you mentioned.
$399 is as low of a price as I've seen.
Days Camped: '16=46 '17=30 '18=51 '19=4
Old 03-01-2019, 01:45 PM   #5
Give some thought to what you might want to add to your generator down the road. Sometimes it makes more sense to get the "fancy schmancy" items all built in. Not a bad idea to have a fuel gauge, hour meter, and if I understand correctly a remaining run time indicator. Probably also indicates when to change oil.
If one is a cheapskate then none of those items justify the cost. If one is thinking more practical they may well end up being a bargain.
Your choice.
I have it on my dog's authority that an afternoon nap is acceptable.
Politically Incorrect since 1943
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 03-01-2019, 02:18 PM   #6
NJKris's Avatar
To make them a little fancier, I added hour meters for maintenance purposes. 10 bucks each on amazon, you just wrap the lead around the spark plug wire. It's tight inside the cabinet, but luckily my hands are not too big. I even got yellow ones to match the yellow cabinet. Looks factory!
Old 03-01-2019, 02:48 PM   #7
SPRING IS COMING!!!
I did the same thing with my Champion... except we got the black one to match... and it looks factory installed!
Old 03-01-2019, 04:37 PM   #8
tc cruiser's Avatar
Sailor Sam
You can get an hour meter for $10 on amazon and it literally takes 10 mins to install.
Tom
edited to add: see above 2 posts.
2018 Flagstaff E-Pro 19 fbs
tc cruiser is offline   Reply With Quote
Old 03-01-2019, 11:08 PM   #9
Thanks everybody for confirming my thoughts on this. And yes, the hour meter is on the list as an add-on. $10-25 versus $150?
I look at myself as frugal. I have no problem paying for useful value. In this case, I don't see much.
Al
S.E. Mich.
Old 03-02-2019, 08:49 AM   #10
dcheatwood's Avatar
I found best deal on champion at Cabela's. So did my brother and nephew a year after mine. They have unannounced sales and you just have to check their site every so often. Good luck. Either one you're looking at is a nice unit.
2018 Forester 3011 DS
