Old 07-18-2017, 07:45 PM   #1
Tirebuilder's Avatar
Dry Camping...
My wife and I are wanting to try "dry camping" at Cades Cove Campground in the Great Smoky Mountains National Park. We are long time campers, but never have we camped anywhere with absolutely NO amenities such as water, electric, sewer, etc. I was just wondering what others that have done this before might recommend as a way to "get started" or things we might need to take our first camping trip without the "comforts" of regular campgrounds. Over thirty years of camping...now retired...and I'm wanting to forsake the conveniences of easy camping for a try "roughing" it. LOL. Hopefully we can make it happen...if it's not really too much trouble. Any help, suggestions, and advice would be welcome. Thanks for all the help and thanks to the Forum for the educational threads that pop up. I have learned a lot on this site. Thanks again.
Tirebuilder is offline   Reply With Quote
Old 07-18-2017, 08:21 PM   #2
woodyrock1's Avatar
I don't have an on board generator so I have two Honda eu2000i paralled which is great for running A/C, microwave (not at same time) and for charging battery. I don't know what model rig you have but if you can fill your fresh water up 100% before final destination that is a plus. I never camped at a park that didn't have at least a few water spigots somewhere but as you stated there aren't any. Water for toilet is a must as I am sure you already know and water for a quick shower. I would only use paper plates and plastic forks to knock out doing dishes. You can always fill up water containers and bring along. I have a few 5 gallon jugs I fill and take as back up. A few cases of water for drinking or brushing teeth. Of course all of this will depend how long you stay dry camping. I have been able to go 5 days without using all my fresh water and not filling my tanks. Ivory soap floats so if there is a stream, river, lake or pond pretend you are going for a dip and have a bar of soap in your bathing suit. If you drop the soap there is no need to worry, it floats like a rubber ducky.
Then you have to beware of the grey and black holding tanks (again I believe you already are aware of this). If you have an outside shower you can wash your hands/face and brush your teeth. I know what people are thinking but even that little bit of water for that adds up and when dry camping those darn tanks seem to fill up quicker than normal.
Hope this helped a little and if you do this you have a great time.
05 Ram 3500 Cummins Dually
14 8280WS Rockwood Sig. Ultra Lite
Prodigy 3 brake Controller
TST 507 TPMS
2017 = 30 nights /
2018 = 7 nights
woodyrock1 is offline   Reply With Quote
Old 07-18-2017, 08:34 PM   #3
bikendan's Avatar
We've been dry campers for 30 years now.
First, will you be wanting to run the a/c or microwave?
If so, you'll need an inverter generator, at least 3000w or two paralleled 2000w units.
If you won't need either, a solar setup is an option to recharge the batteries.
Second, a dual battery setup is necessary, preferably a pair of 6v golf cart batteries.
Third, fresh and gray water can be an issue, depending on tank size. We use a 6 gallon jug for fresh water and a blue tote tank for gray water disposal.
Equalizer WDH
Old 07-18-2017, 09:46 PM   #4
The only amenity you will lack is 120 volts AC but not an issue if you have a generator. Your camper already has the other amenities on board ;-)
7 gallon Aquatainer water containers are great to supplement your fresh water tank. If you don't have a gravity fill for fresh water tank, a cheap harbor freight water pump will make your job easier.
How big is your grey and black water tank?
Water conservation is extremely important. A shower uses about 2.5 gallons per minute. I can shower with about 30 seconds of water usage. I have a other post how I do it.
Washing dishes: Don't do it, use paper plates and solo cups.
Grey water: If fresh water is an issue, drain your grey water into a small bucket and use the grey water to flush your toilet. If grey fills up, I often use it to water the local trees and vegetation regardless of what the enviro-weenies rule say. I often dump my RV's grey water on my lawn when I return home to save water and use the black water on my wife's flower beds (we don't flush TP or use harsh chemicals in our black tank and those flowers love the fertilizer plus it keeps the neighbors indoors on a hot day)
Black Water: On long trips 2-3 weeks in the back country, I urinate in the woods so my wife doesn't have to towards the end of the boondock stay.
A small inverter for TV/DVD player is nice so you don't have to run the generator at night.
2 batteries is a must to prolong battery life by reducing discharge below 50% of battery capacity.
Inverter generator is the only generator to use. Before i had solar, generator would run 2 hours in morning and 2-3 hours in evening to top off batteries and ensure enough juice to run heater all night (we camp at 10,000 ASL so it gets cold each night).
Good luck and have fun. Boondocking is the only camping we do and we love it and I'm sure you will too as long as you don't mind a very quick shower every other day
Other tips:
Get an icemaker if you like ice. My wife is crazy about having ice and one of those $99 units works great.
Hot water heater and fridge on propane 100% of the time. Turn off hot water heater when not needed.
Disconnect your tow vehicle electrically from your camper just to be safe. Several years ago my camper drained my truck batteries overnight...not supposed to happen but it did. Had to run generator to charge RV batteries and then used RV battery to jump start truck.
I planned for 1.5 gallons of gasoline usage per day without air conditioning. I used much less gaso but whatever I didn't need at end of day got dumped into my gas truck's fuel tank.
Level blocks: Lots of boondock sites are not always level and those "Lego" type levelling blocks are awesome. If you have a self leveling camper, I hate you cuz I don't and I'm jealous.
A 5 gallon "Homer" bucket is a nice thing to have for a variety of emergencies and situations.
I burn my paper trash by using it to start my camp fires. Who am I kidding, I also burn plastic and anything else that is flammable. Trash easily builds up on long camping trips while boondocking and trash makes a great fire starter.
If you use your generator to run air-conditioning, realize that the water heater and fridge must be on propane setting. Also realize that running airconditioner and microwave at same time. may not be feasible.
Skyliner is offline   Reply With Quote
Old 07-18-2017, 10:15 PM   #5
Scoundrel
HangDiver's Avatar
When you wash dishes/pots/pans, etc., don't do them after every meal. Do them all at once at the end of the day and you'll use much less water.
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller
Wooden Spoon Survivor
HangDiver is offline   Reply With Quote
Old 07-18-2017, 10:19 PM   #6
Evereddie's Avatar
Since this is your first time doing this I think paper disposable stuff will be OK. Gotta keep water use low.
The big question is: do you have a generator? If not are you going to buy one. If neither you really should have 2 batteries.
There are 10 types of people in the world.
Those that know binary, and those that don't.
2013:31 / 2014:51 / 2015:58 / 2016:37 / 2017:46
2018:16
Total 239
Evereddie is offline   Reply With Quote
Old 07-18-2017, 10:37 PM   #7
Length of time comes into play here! If it is Only for 2 days you should be fine for Water/43 gal,Gray/45 Gal,Black/45 Gal if Longer you will need More Water! Catch gray water and use it for Black Flush! You will need a Geny regardless, by the time you run all 3 slides in/out,run water pump,run Refer on gas,unless it is a Optional Residential,then your Power needs jumped way up,and we have not even used the Fans or lights,let alone if it gets Hot & Muggy in the Valley and you want AC let alone with that much Square Foot to Cool you probably have 2 AC units= More Power,radio & TV,charge cell phones & Tablets/Comp! Yes you will need & Want a Big Genny! Youroo!!
Old 07-18-2017, 11:37 PM   #8
Well let's see... Facilities:
Cades Cove combines the feel of primitive camping with the modern convenience of flush toilets and drinking water. A camp store provides visitors with basic necessities as well as bike rentals.
That's not exactly "roughing it" by my standards, but then I tent camped "dispersed" in National Forests for years. All kidding aside, the long pole is going to be how many days you are planning to camp. Then the tank and battery capacities come into play. My take is that most RVs can do 3 or 4 days of dry camping with some restraint on part of the occupants (no long showers, minimize things running on inverters, turn off unneeded lights etc.) You can stretch it by using the campground toilets, cleaning dishes with little water and pour dishwater into the black tank (given that you do most of your business elsewhere). Then you can add fresh water from the faucets via a water container, and maybe run a generator for a few hours to recharge batteries unless you have a solar setup already.
TheGerman is offline   Reply With Quote
Old 07-30-2017, 09:12 PM   #9
Golfnbike13's Avatar
Would love to know how this trip goes and more importantly some good sites to look for there. We really want to go there but worried about finding a good camper spot.
Golfnbike13 is offline   Reply With Quote
Old 08-23-2017, 11:48 PM   #10
hootn's Avatar
ive camped in cades cove with the pop up a couple of times. all the bath houses have water to fill up containers, they have a dump station. just no water hook ups at the site or power. I believe no generators are allowed.
we are going the 23 of October to cades cove. checked the other day and I think there is only a few spots remaining. you can go to their web site and look at each site to get a idea of how the site looks. I made my reservations back in april or may, whenever they opened them up to set your reservations. of course the one I wanted was taken. being at the time I was planning of getting the tt I just wasn't sure so I got one for both but it will work out best with the tt.
of course the pop up was set up for boon docking, ive used it to camp in the national forest turkey hunting and where I camped there is nothing just a cleared spot.
scott
hootn is offline   Reply With Quote
camping, dry camping
