Old 01-15-2014, 05:39 PM   #1
Dry Camping
Dry camping here we come.
I have been reading as much and as many of the posting on this subject and it is enough to warp the brain.
All makes sense when reading it, but.........
I think I am ready to put this new knowledge (?) to work, so here goes.
Any comment/help would be appreciated.
I am installing a xantrex 2000 watt pro watt sw inverter, w/GFI plugs, in my TT.
Using 4/0 wire from it to batteries, (about a 4-5 foot run), two Trojan T-105 Plus batteries, w/250 amp fuse, (+) pos side.
Do I have to change the wiring run to my exsisting WFCO 8955AN converter/charger or just keep it hooked up to the + side of the battery on top of the new 4/0 wire.
In addition, I will be installing a Trimetric 2025RV to monitor the system. All neg (-) side wiring will go through the 500amp shunt as per the instructions.
I will only be using the inverter to plug in my CPAP machine at night.
I have a Powerhouse 3100i generator to charge batteries when needed.
What am I missing?
2002 GMC Sierra 2500HD Duramax
2008 Rockwood Sig Ultra Lite 8315SS
Livin the Life is offline   Reply With Quote
Old 01-17-2014, 07:39 AM   #2
RPAspey's Avatar
Your setup sounds about right. How much power does the CPAP use?
2000 Cherokee, LEDs, solar, inverter, etc. '07 Tundra 5.7L DC-LB, modded as well.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is online now   Reply With Quote
Old 04-09-2014, 08:27 PM   #3
I found it easier and cheaper to get a 12v adapter for my CPAP machine and install a 12v plug by my bed. I think it cost me about $25 and works perfectly.
2009 Rockwood 2701SS
2008 Tundra Crewmax 5.7
bob7794 is offline   Reply With Quote
Old 05-25-2014, 12:28 PM   #4
That is what I did for the DW. We have 700 ah of house batteries and an inverter but efficiency is to use DC when you can. It saves the loss that an inverter uses. With humidifier, her CPAP uses about 6 amps dc
tycham is offline   Reply With Quote
Old 05-25-2014, 12:31 PM   #5
That is the inverter we are using. Let me know what you think of the 2025 RV. I am either doing that or the Victron
Old 05-25-2014, 01:58 PM   #6
Denver, CO
garbonz's Avatar
"Do I have to change the wiring run to my exsisting WFCO 8955AN converter/charger or just keep it hooked up to the + side of the battery on top of the new 4/0 wire"
Yep that's all. Just make sure you don 't run the converter from the inverter.
2017 Fuse 23T
boondocking, camping, dry camping, inverter, trimetric, wfco, wiring, xantrex
