Old 05-02-2019, 06:23 PM   #1
Extended season package
I have a 2017 36ft heritage glen 5th wheel. It says extended season package on the panel next to the entrance. My "dealer" could not tell me what that meant. Help
KenClick image for larger version
not2yzsr is offline   Reply With Quote
Old 05-02-2019, 06:31 PM   #2
Lacey's Spring, AL
formerFR's Avatar
more than likely just a marketing term, maybe a little more insulation... but not quite 'four seasons'.
The Turners
'14 Thor Palazzo 33.3 diesel
KingTailgater2 Dish, 100w/5amps roof SOLAR, BlueOx,
100,000+mi since '14, US, Alaska, Canada, now Lacey's Spring, AL : )
formerFR is offline   Reply With Quote
Old 05-03-2019, 01:04 AM   #3
bikendan's Avatar
Yep, at best, it's a 3 season trailer.
Equalizer WDH
Old 05-03-2019, 02:53 PM   #4
Retired Panpsychist
Theo's Avatar
I saw something like this at Hershey last fall on a 5th-wheel...not sure of the make, though. I think it was called a "Polar Package". IIRC, the salesperson said the package included higher R-value insulation, heated underbelly, a higher output furnace and (maybe?) heated holding tanks.
Not sure that's the same on a Heritage Glen. Might you give the HG offices a call?
Theo & Carol
2007 GoldenDoodle ("Cooper")
2020 Rockwood Roo 23IKSS
2015 F-150 SCab, 5.0L, 3.73, HD Towing Pkg (53A)
Theo is offline   Reply With Quote
Old 05-03-2019, 03:03 PM   #5
koller1509's Avatar
Your correct, I have the polar package and it is higher R value (R38 in floor and ceiling, R18 in walls and R11 in the slides), heated underbelly, and 12 volt tank heaters. It works well (have camped down into single digits several times) however it is not a true 4 seasons option for full time living.
Larry
2014 Ram 3500 Dually 4x4 6.7 Cummins
2017 Sandpiper 378FB
koller1509 is offline   Reply With Quote
Old 05-04-2019, 10:14 PM   #6
Extended Season
Thank you, I appreciate your reply
Old 05-05-2019, 08:24 AM   #7
As someone said on here the four seasons camper is if you full time in Florida
spock123 is offline   Reply With Quote
Old 05-08-2019, 11:59 AM   #8
Question
I am thinking about getting tank heaters...during the time of year that they would be utilized I would be at hunting camp boon-docking . I would generally only using generator for charging my 4 6 volt batteries while watching some TV in the evening...Are they thermostatically operated? I don't imagine they would need to operate all the time as only need to be 33 degrees in the tanks? I am mainly concerned about battery conservation. I would love to be able to use my inside plumbing as taking outside showers in sub 20 temps gets old...as does the outdoor privy in the AM!!!!!
Thanks in advance for any comments!
Nemisportsman is offline   Reply With Quote
Old 05-20-2019, 09:31 PM   #9
Geo Pro Owner
Brian Brown's Avatar
I was wondering the same thing about a built in thermostat. My 2019 Geo Pro came with tank heaters, but haven't tried them yet. This weekend it is going to be around freezing in Rocky Mountain National Park so I'll test it out.
This one on etrailer says it has a built in thermostat.
https://www.etrailer.com/RV-Fresh-Wa...77-000164.html
Description says:
Built-in thermostat automatically operates the heater pad
Turns on when the tank or step temperature reaches 45 degrees F
Turns off when the tank or step temperature reaches 67 degrees F
Seems like those temps are really high though. Not sure I would want the heater to warm the water up to 67 degrees F.
2019 Rockwood Geo Pro 19BH w/off road package
2014 Acura MDX
Fastway E2 WDH - 6k Gtw, 600 Tw
Brian Brown is offline   Reply With Quote
Old 06-29-2019, 09:01 AM   #10
On my 2019 Sunseeker 3010DS, the Arctic Pkg has the better insulation, heated under belly (which means one extra furnace vent dumps into the area), and 12VDC immersion heaters for the tanks. They are thermostatically controlled, and will only work below 40 degrees. I think leaving them on would be a considerable drain on the batteries, without solar to keep them topped off. Living here in Idaho, I will be able to speak more on the issue about September!
Blank is offline   Reply With Quote
