Old 09-01-2013, 07:58 PM   #21
simplyrwc's Avatar
Originally Posted by chiefly1 View Post
I would suggest you also change some of the main use light bulbs to LED's. That will save you a ton of battery juice - they use about 90% less power. Might want to get two 6 volt batteries if you have the room in a separate battery bank and consider a solar panel as well. Take your time and see what works for you guys.
I have been considering the LED lights.
2 6 volt or can I daisy chain 2 12 volt? Is one way better than the other?
2004 V10 4X4 Excursion
2014 FR Wildwood 32BHDS
2013 Days Camped 14
simplyrwc is offline   Reply With Quote
Old 09-01-2013, 09:09 PM   #22
chiefly1's Avatar
You can set up two 12 volts and/or 2 6 volt batteries or both in separate banks with a switch to control them. Lots of options to consider but basically the 2- 6 volt option gives you more power. I would charge your original battery and see of it is good then add it to your system. And I would get a battery tender which is a 4 stage charger to really charge your batteries before you start out next time.
chiefly1 is offline   Reply With Quote
Old 09-06-2013, 05:25 AM   #23
Swaggler's Avatar
Originally Posted by simplyrwc View Post
Out of water already...thinking maybe I am doing something wrong when I fill up because we have barley used any or we are going through it faster than I realize.
Lol
I had a similar experience my first time dry camping with DW and stepson. We used all of our fresh water the first day. I couldn't believe it and thought something was wrong lol. Now we carry a 6 gallon to refill the fresh tank and a 12 gallon tote that we use to "dump" the grey tank each morning. We also had to change our water use habits to be more conservative.
Always believe that you will ultimately succeed at whatever you do, and never forget the value of persistence, discipline, and determination.
Swaggler is offline   Reply With Quote
Old 09-06-2013, 05:36 AM   #24
Swaggler's Avatar
Originally Posted by acadianbob View Post
Yep, it is. And unfortunately you cannot access that 6 gallons in the hot water tank once the main tank is dry. No water to push it through. So, it is really very misleading . . . . perhaps dishonest.
+1 to that. The specs for our TT say 42 gallon fresh capacity. However, the placard on the TT lists the weight of a full tank as 300 lbs. I did the math... 300 lbs at 8.3 lbs per gallon is only 36 gallons. I couldn't figure where the "extra" 6 gallons were until after reading this thread. I guess they "hide" 6 gallons in the hot water tank on the spec sheet.
