Old 08-31-2013, 01:20 AM   #1
simplyrwc's Avatar
First boondocking trip
Third trip in new trailer and first boondocking triip
Discovering some things...
Fan(not AC) won't turn on using battery power
Out of water already...thinking maybe I am doing something wrong when I fill up because we have barley used any or we are going through it faster than I realize.
Plugs won't charge cell phone. Will just use truck.
Bugs love the inside of my trailer!
Should have done this without the wife n kids one time so I could figure it out a little more stress free! Lol
2004 V10 4X4 Excursion
2014 FR Wildwood 32BHDS
2013 Days Camped 14
simplyrwc is offline   Reply With Quote
Old 08-31-2013, 03:30 AM   #2
bikendan's Avatar
did you boondock or dry camp?
when you say "plugs", do you mean the regular 110vAC outlets? if so, they don't work on battery power, only shore power or hooked to a generator. you could install an inverter to use for charging cell phones or watching tv.
if you've never dry camped or boondocked, you probably are using more water than you think. we were popup campers for many years and never had any hookups, so we learned to conserve water and battery power.
when you say "fan", which fan are you talking about? there are a number of fans that operate off the battery. converter fan, bathroom fan, stove fan and so on.
Equalizer WDH
Old 08-31-2013, 09:12 AM   #3
simplyrwc's Avatar
If I understand the difference correctly I am boondocking...I am along a river not in a designated campground with no utilities.
yes i was talking about the 110vAC outlets. For some reason I thought they would work on battery.
You are correct I have never done this before(with a trailer) I have always tent camped so this is all new to me. When I filled up the tank at home and opened the faucets to fill the hot water heater and to push the air out of the lines the pump sounded like it was sucking air. In a rush I dismissed it thinking I was not giving it enough time. It was making the same sound so I am not really sure if I am actually out of water or if I am just not getting a good prime? My water level sensors on the fresh water have never been accurrate so I filled the tank until water was coming back out. I read in another post that sometimes if you fill too fast it will put water in the vent tube and not allow the tank to fill all the way. So I am not sure if that is what I did or if I actually used all the water. I am working so I have only had limited time to investigate.
On my thermostat I have 3 settings "fan" "Cool" "Heat" ....I was thinking on "Fan" I would be able to run off of the battery.
Old 08-31-2013, 09:27 AM   #4
Nope,A/C (FAN) is 110. Youroo!! Furnace fan runs on (12V).
Old 08-31-2013, 11:59 AM   #5
Geojudi59's Avatar
Fresh Water Tank
Sounds like your fresh water tank might be air bound so..... your only getting maybe 1/2 full. When the water starts to spurt out of fill box,stop it for a minute or two Then slow the fill rate down.
Mind does the same thing..
George & Judy... Our Quincy is gone but Never forgotten.
we now Have a Golden Doodle pup
2010 Brookstone. 2400 Watts of solar 1500w inverter,4 T105's
Geojudi59 is offline   Reply With Quote
Old 08-31-2013, 08:43 PM   #6
simplyrwc's Avatar
I guess one more question. Does a propane/110 fridge need battery power to run with propane? Reason is wife called today saying it wasn't cooling all the time but she was also having to charge the battery. Guess I need to invest in generator.
2013 Days Camped 14
Old 08-31-2013, 09:15 PM   #7
Batts-toy's Avatar
Running the Frig on propane requires the battery for the electronics circuits to operate the frig controls propane valve in the frig etc. Absolutely need a gen for camping without shore power. Be sure and get a quiet gen then you can use it in campgrounds and not upset the neighbors, also if you go large enough on the gen with 30 amp service you can power your 110v circuits when running the gen.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 08-31-2013, 09:29 PM   #8
bikendan's Avatar
as was said, yes the fridge needs the 12v battery power to run the fridge on propane.
how is she charging the battery, with the tow vehicle?
if you prefer to camp at Calif. state parks, like we do, dry camping is the reality, since less than 1% of our state park campsites, have any hookups.
so we have two deep cycle batteries, a 400w inverter and a Honda 2000 inverter generator. we also have a 6 gallon water jug and a 15 gallon blue tote tank.
all these items are really needed if you plan on dry camping or boondocking for more than a couple of days without hookups.
Equalizer WDH
Old 08-31-2013, 09:56 PM   #9
Broadway Joe's Avatar
When you get home, try "boondocking" without power or water in your driveway to see what works and what doesn't. Much easier then doing it on the fly. Hope your wife will not be stranded for long.
Broadway Joe is offline   Reply With Quote
Old 09-01-2013, 05:52 AM   #10
sail2liv's Avatar
When you say wife and kids along there will never be enough water or large enough holding tank.....or bank of batteries that will supply needs ..... you will be lucky to make thru one night.....I found a water meter gauge to go on end of hose at CW on clearance.....seems to be very accurate.....digital readout....data for my trailer say 38 gal fresh water.....but most I can get in tank when pump no longer draws water is 32 gal....so thinking hot water tank included in that number....good luck....if you camp like you are in a tent, it will work out in trailer.....
2011 Silverado 2500HD 6.0 Gas 3.73
2013 Flagstaff 8524 RLWS
1978 Cape Dory Ketch
sail2liv is offline   Reply With Quote
