Old 09-13-2014, 12:37 PM   #1
Campsters's Avatar
Flagstaff Microlite battery question
If all we ran on the on board battery for our Microlite 21FBRS was a small house fan, do you think the battery would last for 9 hours? We have propane for refridgerater.
Campsters is offline   Reply With Quote
Old 09-13-2014, 03:48 PM   #2
Blackrock's Avatar
There is no 110v power available when not hooked to shore power. You can use a little fan like this which will run a long time on battery power.
Amazon.com: Peak PKC0JH 12 Volt 6" Clip-on Fan: Automotive
I have a dual battery setup on my Micro lite 25DS and can run my heater all night long plus lights and water pump.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is offline   Reply With Quote
Old 09-13-2014, 04:19 PM   #3
Campsters's Avatar
We are able to have 110 run this way. Of course we would not use the tv as it would really drain the battery. But as you can see, it does work. Just not sure how long with a small fan. I have read not to totally drain the battery as you will shorten the life. I am looking for about 4 hours of usage. possible?
Old 09-13-2014, 11:49 PM   #4
Evereddie's Avatar
Can't tell you much about actual run time but if you can use a 12 volt fan instead of a 110 volt one run off an inverter it will give you more run time. There is an amount of waste in an inverter that you will not get with a direct 12 volt fan.
Evereddie is offline   Reply With Quote
Old 09-16-2014, 12:37 PM   #5
There will be more than just the fan running off of the battery i.e., water pump, carbon monoxide & propane detectors, water heater electronic ignition, and lights. Be sure to turn off your TV amp. Don't discharge your battery more than half way. If you do you will reduce the life of it. Always be sure the water is topped off.
2009 Rockwood 2701SS
2008 Tundra Crewmax 5.7
bob7794 is offline   Reply With Quote
