Old 12-10-2014, 02:54 PM   #11
rotorhead1250's Avatar
Furnace running on battery
Oh yea, I should of added that about running the generator all night. Im usually in the woods. Nearest camper is a mile or five away.
I try and keep the batteries fully charged all the time.
Matt & Kathie
2017 Grey Wolf 27RR
rotorhead1250 is offline   Reply With Quote
Old 12-10-2014, 02:56 PM   #12
KyDan's Avatar
Originally Posted by chaslorr View Post
How long will my battery run the furnace when not connected to electricity? Is it reasonable to assume it would power it for a night stop over, and then after a days driving and charging from the tow vehicle, power it for another night. This would be without using any other draws such as lights and such. Have Rockwood Minilite 2109S with single 12 volt battery.
There are so many variables here it's very difficult to give a good answer.
First lets cut to the chaise- many folks falsely believe that they can recharge
the trailer battery by hooking up to their tow vehicle and driving.
Wrong! Since the trailer battery is so far down stream the voltage regulator in the engine charges the engine battery then cuts back
on voltage so as not to over charge the engine battery. This leaves the
trailer battery with very little charge going to it.
2nd- you might be OK for 1 night on battery with the furnace if you don't
turn the thermostat up too high. We camped several times with one
battery and were fine the first night. The 2nd nite we ran out of juice....
It also depends on how cold the nights are how big your trailer is etc.
Hope this helps!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 12-10-2014, 03:00 PM   #13
Dry camping/ boondocking. Sorry, thought they were the same thing. Guess I was mistaken.
Matt & Kathie
2017 Grey Wolf 27RR
Old 12-10-2014, 03:27 PM   #14
Many factors at play here, a couple of the big ones:
1. Power draw from heater - how many times it runs and how long for each run (largely a function of outside temp, thermostat setting and amount of heat loss in TT)
2. Battery capacity (and health of battery) plus other items using battery.
You could do a lot of testing and math to figure our the real numbers but folks usually just get a feeling for things after using their rigs for awhile.
All that being said, we can get 3 nights easily on a fresh Group 29 battery using the heater in our pop-up, and will go a week in Yosemite using two G29 batteries. We do carry a Yamaha 2400 genny as a back up for the week long trips - but it mostly gets used to power DD & DW's hair dryer!
Martingale is offline   Reply With Quote
Old 12-10-2014, 03:33 PM   #15
Fulltime family RVer
No clue, but I may find out if my new Group 27 battery will do it. Depends if we make it to a Camping World and if they have space available for us to park overnight. I'll end up driving 10-12 hours the next day but I expect to have electric hookups that 2nd night.
ependydad is online now   Reply With Quote
Old 12-10-2014, 03:37 PM   #16
Originally Posted by rotorhead1250 View Post
When I'm dry camping and it's cold enough for heat, I run my Yamaha 2400 gen all night long. It uses exactly $2.21 in fuel at current prices and my batteries remain fully charged. Makes me a happy camper.
You are funnin us right? LOL
rana is offline   Reply With Quote
Old 12-10-2014, 03:47 PM   #17
Ummm.. you DO realize that sound travels for miles? That out in the sticks the sound and fumes from your burning genset severely impacts the immediate wildlife patterns? Many with nocturnal tendencies... Simply the vibration can affect wildlife patterns for weeks...
That's a real good way to wake up to sugar in your genset. LOL
I don't mean to be harsh... but if you don't have the respect to conform to where you are.. you have no business being there.
I will step of my soap box...
Old 12-10-2014, 03:52 PM   #18
SKnight's Avatar
Originally Posted by gljurczyk View Post
That brings up a good question do you know how many amps are sent to your battery by your alternator? Always wondered that. In the Marine industry they have alternators that will put out 125 amps. For shorter engine running time on a sail boat. It also would replace the one on your TV. I have never measured it, Just wondering if you know?
It's not the alternator actually. The charging wire has every amp the system can provide at it's disposal, batteries, alternator and all. The limiting factor is the size of the wire. A wire will only transfer so much energy in relation to it's size. The trailer battery wire is usually 12 gauge or so, and is run through the fuse block meaning several connections which limits energy transfer also.
It will provide 10-15 amps of charging power, but when the battery has been drained 40-50 amps then that means roughly 3-4 hours to top up.
Now, and this is something I've been considering, if you ran a 0 or 2 gauge cable set back to the battery it will charge it at the full rate your alternator can provide. The alternator on my truck is 140 or 165 amps (I don't recall.) and a battery will soak that up at a probably 40-50 actual draw (Batteries can only absorb energy so fast.) so now we're charging things up in an hour or so.
I've thought about adding that type of setup as a backup plan, in case my converter fails or I'm about to travel but only an hour or so away. You can use an onboard jumpercable set that has the large spade connections such as what a wrecker uses. Leave the regular setup for every day, but if you need the big energy transfer you plug in the umbilical cord and away you go.
Old 12-10-2014, 04:15 PM   #19
Apologies in part.. ;-) I've just had this yahoo over on the other side of the hill doing the same thing the past 3 nights.. so my nerves are a bit frazzled. LOL
Old 12-10-2014, 04:49 PM   #20
Yarome, that's twice you've laughed at me for stating i run my generator all night. What is the problem with that? You say I have no business being in the woods? Really? Who are you to tell me where I can or can't camp? That gen runs at 53 db and a normal conversation is 60 db so your point is what? Sorry to everyone else for this but I must defend stupid remarks aimed at me.
Matt & Kathie
2017 Grey Wolf 27RR
battery, furnace
