Old 07-08-2018, 12:46 PM   #1
Generator
Iím looking at a Honda EU2200i or Yamaha EF2000iSV2 generator for dry camping. My in-laws want to ďtap intoĒ our generator on a trip. He thinks it will not be often when we are both dry camping together and thinks we can share ONE generator for TWO travel trailers. I canNOT find any info on hooking up 2 RVs to one generator...I only see info on paralleling 2 generators. Anyone have any info on this?? Thanks in advance!!
Also, is the generators listed above too much power for ONE 30í trailer?? (If we were just getting a generator for our rig only)
Thanks again!!
jsslo is offline   Reply With Quote
Old 07-08-2018, 01:01 PM   #2
Twice's Avatar
Get the Honda, I got rid of my Yamahas because of so many problems with them. I went with the Honda EU3000i.
As far a if you can run to trailers it depends on what you plan on running. Even the Honda you are talking about may not run the AC in your trailer.
Do some more research on what size your appliances are and capabilities of the genny you choose.
Good luck!
Tammy and Tracey
and our doggie Jaq
2015 Ram 2500 Mega Cab w/ Cummins 4X4
2015 Coachmen Chaparral 336 TSIK
Twice is offline   Reply With Quote
Old 07-08-2018, 01:09 PM   #3
Bluepill's Avatar
If you will only be using the genny to recharge the batteries and maybe run a small microwave or coffee maker, you can do it as long as you coordinate usage. By that, I mean you can't both use larger appliances at the same time. Using the A/C is out of the question.
No problem wiring them to the genny. Attach one camper's 30 AMP shore power line to the 30 AMP outlet, and the other one to the 15 AMP outlet with a 15/30 dogbone converter.
https://www.amazon.com/Camco-Dogbone...ds=camco+55165
Worst that can happen is that you have to buy another genny anyway.
Old 07-14-2018, 10:10 AM   #4
I am curios about the generator size thing.
We plugged our fifth wheel into 30 amp survive and somehow both ac units came on and ran. Ocassional convection oven use as well as the converter. Never an issue on too much use. Even used the dryer.
We got home and for the devil of it I plugged into the house 20 amp service via a 100í extension and one ac came on and has run in 90 degree weather with the converter as well. When I tried a 1500 watt heater the breaker tripped.
Makes me wonder if a Honda 2200 would power my ac, one 15000 btu unit. If I turned other breakers off? Draws less than 15 amps running. It is a new unit.
tomkatb is offline   Reply With Quote
Old 07-28-2018, 03:12 AM   #5
Splitshaft's Avatar
A EU2200i would certainly power an AC drawing 15-amps at sea level. My EU2000i will generate 1,800 watts all day long at sea level running and old 13,500 btu AC. The only problem that might come up is thin air at elevation reducing engine power. As long as the engine can produce the horsepower needed to carry the load, the generator inverter has the capacity to power it.
There is a significant difference between a Honda generator and a circuit breaker on utility power. The Honda goes into overload almost right at its peak current rating. A circuit breaker functions on a time and current curve, such that a 20-amp circuit breaker can carry 22 or 24 amps often for an hour or more without tripping and even more current for shorter periods of time. The 30-amp breaker could carry 33 amps for an hour or more and I have loaded 30-amp breakers to 40 amps running the microwave for short periods without tripping a 30-amp circuit breaker due to the time and current needed to trip it. A Honda isnít going to work like a circuit breaker on utility power though.
That said, we make due with the EU2000i for charging the batteries in ours and our daughterís RVís. We do have to unplug one RV from the Honda if someone needs to use their microwave oven. And when first charging low batteries, two converters can load a 2,000-watt generator for all it is worth requiring one RV be charged separately for a short while to drop the output of one converter as the batteries become charged so the other RV can be plugged in and charge too. Power management 101.
Splitshaft is offline   Reply With Quote
Old 07-28-2018, 04:57 AM   #6
Good luck!
Sorry to hear of the bad luck you had with the Yamaha. However, I need to point out that in a decade of reading posts on generators, this is the FIRST negative one I've ever read on Yamaha. Personally, I'm in year 7 with mine and it has never stumbled in the face of a hard life.
From experience, I would not buy one that can "probably" run the A/C. When you need it, it is too important of a job. I went with the Yamaha 2400 for that reason, you could also consider the Honda 3000 or pair of 2000's. You can run anything you have and sharing becomes easier.
Regarding the extra expense, you have to remember that this may very well be a lifetime purchase. You won't remember the extra expense in 20 years.
2013 F150, EBoost,4x4,CC, MaxTow
2015 Surveyor 245BHS
tragusa3 is offline   Reply With Quote
Old 07-28-2018, 06:42 AM   #7
I had a pair of Honda 2000's and loved them. Sold my trailer and the generators. Now a 5th wheel and an Onan 5500. Can't go wrong with paralleling two Hondas.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
mwdilday is offline   Reply With Quote
Old 07-28-2018, 07:04 AM   #8
OK you buy 2 Honda 2000 that can be Paralleled,each of you use 1 if the Needs surpass the output needed,Unhook your FIL and enjoy YOUR Generators! Youroo!!
Old 07-28-2018, 08:09 AM   #9
NMWildcat's Avatar
Can't agree more. We tried to "share" our two Hondas with the BIL ONCE. . That was enough. I spent a lot of time resetting them and cussing. And we weren't even trying to use a/c.
Scott and Liz - Southern NM
Old 07-28-2018, 08:30 AM   #10
dcheatwood's Avatar
Yes. You can plug both tt into one generator. BUT make sure AC's are OFF. Water heaters are on LP. Fridges are on LP. And no one uses hairdryer or other high amp accessories. It'll give you light, water pump and charge batteries. Brothers and I do it with a 3000 w while dry camping with 3 tts.
2018 Forester 3011 DS
generator
