Originally Posted by garbonz
Since the noise scale is logarithmic about the same is a far cry from the same as it only takes a 3decibel difference to double the sound level that your ears hear.
I would suggest actually listening to any generator that you are thinking of to see if you can stand it in the application that you intend it for. Also be cautious about the exhaust as these units (all of then) put out about 30,000 ppm of carbon monoxide which will kill you in a few breaths, if not diluted by fresh air. There have been reports of people operating a generator close to their TT's and with the wrong wind condition, and an open window, being overcome by the CO.
IMO
It don't help when they give their specs differently. I ordered a pair of Champion 2000i with paralell connector should be here Friday, anyway the Champion spec said 53 Db from 23 feet away. Honda sometimes says 53 Db and sometimes 58 Db, without stating distance on either. Well I guesss I'll see what 53 Db from 23 feet away sounds like.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
