Old 02-28-2013, 05:55 PM   #11
Travels with puppies
generator help
We are new to the rv world. Just purchased a Cedar Creek Silverback trailer....37'. We want to get a generator....but not sure how big, what fuel type and what the heck is EVAP.....and whatever it is do we need it???!!!!!
Also, if we go gasoline does the fuel tank have to be metal...I read that somewhere.
What are the best RV generators?
jackiestimpson is offline   Reply With Quote
Old 03-02-2013, 04:47 PM   #12
bikendan's Avatar
you need to provide more info. do you need it for a/c? do you have two a/c's?
you stated you're NASCAR fans. you don't need a quiet generator for that type of usage.
but if you plan on using it in a campground, then it narrows your choices, since noise will be a bigger issue.
the Honda/Yamaha inverter generators are the gold standard in RV gennies.
they have the lowest noise ratings of any brand.
to run a single a/c, you'll need a minimum of 3000 watts of power. if you have two a/c's, you'll need a bigger one.
IMHO, a set of paralleled H or Y 2000w units are the best choices.
if you don't need the a/c, then one 50lb. unit will run everything else.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 03-02-2013, 08:55 PM   #13
more info
We have just one a/c......and a microwave. We are thinking of a 4,000 watt(?) generator. Researched Cummins Onan and Honda so far. One person suggested an inverter ? We were thinking gas originally but now are going more for propane. Thought about mounting on the back of the trailer but now leaning more towards carrying it in the truck bed. The more we read and research the more confused we are! We don't think we will use the generator a lot because we plan to mostly stay at military bases or campgrounds, but would like to have it for camping at NASCAR races and in other situations that may arise.
Old 03-02-2013, 09:00 PM   #14
bikendan's Avatar
it's an inverter generator, that was recommended.
an inverter is something different. it converts 12v DC to 110v AC.
again, pay attention to the noise level ratings. anything under 60db would be acceptable in a campground. anything over would probably be too loud.
also, pay attention the weights. i don't know of any propane-powered generator that is portable.
Old 03-02-2013, 10:34 PM   #15
Originally Posted by DAISY BOYKIN View Post
Boliy Generator Boliy Guy
I use a Boliy and I am very happy with it. It will run a 15 BTU a/c, microwave, and just about anything else. Weighs 68# dry.
You can get it manual, electric, remote start.
I modified mine to run 16 HOURS.
Excuse my ignorance but how did you do that mod to have it run 16 hours. Was considering buying one but don't want to have to add gas every 4 hours
rgdds is offline   Reply With Quote
Old 03-02-2013, 11:19 PM   #16
10x
Who sells the Boliy gen?
10x is offline   Reply With Quote
Old 03-03-2013, 02:05 PM   #17
dezeldad's Avatar
I bought my boliy from Amazon.com.
Mine certainly runs longer than 4 hours on a tank of fuel, even with the econo mode off and the AC on. At least 6 and more like 8 as best I can recall. Runs forever on econo mode and in that mode, very quite. Will be using again at Bristol in two weeks.
dezeldad is offline   Reply With Quote
Old 03-03-2013, 02:46 PM   #18
bikendan's Avatar
generally sold on the Internet. not many S&B places carry them in stock.
and warranty service is iffy.
Old 03-05-2013, 07:54 AM   #19
Catsailor's Avatar
I recently purchased a Yamaha EF6300iSDE generator for our 35Qb4 with 2 AC's. I have it stored in the front bay and find it easy to load with a folding aluminum ramp. I will be adding a sliding drawer that will allow me to not have to unload generator from RV to run it. I found this gen-set more than sufficient to run anything I need on my RV. I also find the remote start option very nice to be able to start and stop from anywhere within proximity with a key fob.
Name:	IMG_1907 (Large).jpg
______________________________
2002 Ford F350 7.3 Powerstroke
2013 CC Silverback 35QB4
Catsailor is offline   Reply With Quote
Old 03-05-2013, 08:15 AM   #20
What happens if you are using a generator and it begins to rain? Do you have to shut it off and cover it?
comfun1 is offline   Reply With Quote
