06-23-2011, 06:00 PM
#41
Originally Posted by bean
Lou,
How do you like your Yamaha generator ?
I was thinking about getting the EF2400iSHC version. It's about $1400 and weighs 75 lbs. Any comments on the EF2400iSHC ?
Thanks,
Bean
We have the EF2400iSCH and love it. We have used it for power outages as well and boondocking. It is extremely quiet. We heard one like herk's a few years ago and were able to have a conversation while standing right next to it without having to raise our voices. We could even hear other generators running at other camp sites.
We also use Sta-Bil in all of our equipment and have never had any issues of thing starting after sitting extended periods of time.
06-24-2011, 09:21 AM
#42
For those that don't know there are 12 volt powered HD televisions out there. I have a Sky something 19 inch screen Hd with built in dvd player that works totally on 12 volts. So nice when boondocking or just spending the night somewhere that the generator or 110 volts is not required. If anyone wants to know brand and model I will get it for them.. I believe it was around $450.
06-24-2011, 10:49 AM
#43
Originally Posted by Hybrid21SS
I was looking at Home depot and Lowes sites and non seem to mention they have a specific 30 amp RV plug. Is it rare for a generator to have one?
yes, it isn't common, but a few of the new Chinese-made inverter generators do have them. Boliy is one of those and has been around for about 4-5 years.
06-24-2011, 11:05 AM
#44
I am looking at this for an "outside TV"
22 Inch Naxa NT-2202 12 Volt AC/DC Widescreen Full 1080p HD LED TV w/ ATSC Digital Tuner
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
06-24-2011, 11:07 AM
#45
I got one of these:
Gentron 3500 watt RV generator | GeneratorDepot.us
It came with the trailer. It is a little loud, but it is nice to have the 30 amp RV plug.
Matt
2014 GMC Sierra 3500 Denali SRW
2016 Dutchman Rubicon 2905
06-24-2011, 11:25 AM
#46
The 12 volt unit I have is a a Skyworth 19 inch. It is HD but I am sure it is only 720p but with that small of screen I am not sure you can tell the difference if it was a 1080p. I love it particularly the 12 volt deal works great since it doesn't need anything more than the battery. I wasn't sure if the Naxa has a built in cd player but the Skyworth does. One problem with Skyworth when I bought it two years plus ago it was around $400. I love the price of the Naxa. Please let me know how it works. I could use one more set however, I would like somehting in the 32 inch range 12 volts with cd player.
06-24-2011, 11:43 AM
#47
I have just googled Skyworth and 19 inch with cd and 12 volts are now around $265. I guess I could have waited.....
06-26-2011, 08:24 AM
#48
Although quite a jump in price from the 22" model, Naxa also has a 24" 12-volt model. For boondocking/dry camping, I think I would prefer the Naxa model simply from what I am reading, it seems to draw less power than the Skyworth.
Great....another item on the "wish list" that I have to find $$$ for. Stop it! You guys are killing me!
Glenn & Beth (Dad & Mom)
David & Audra (16 year old twins)
06-26-2011, 12:37 PM
#49
Originally Posted by herk7769
i just purchased this Haier 22" LED on Amazon. i opted for the refurbished to save $$$. paid $149 + 0 ship + 0 tax. arrived in 7 days.
got it in "white". has just a few superficial surface scratches, otherwise works great!
one benefit, it is DC powered using an AC adapter like a laptop.
i'm searching for a 12 volt-4amp (48 watt) DC cigarette lighter car plug so that i don't have to use a small inverter.
Amazon.com: Haier HL22XSLW2 White 22-Inch Ultra Slim LED LCD HDTV: Electronics
06-27-2011, 12:00 AM
#50
First off- where do you live?
Second, have you confirmed the wattage it's using? My 12" TV is spec'd for 24 watts; but I've never seen it use more than 15 watts.
Wolf Pup T16P owner
"The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine." - Abraham Lincoln
06-27-2011, 12:28 AM
#51
I live in southern california (usa). Don't know why it doesn't show up as part of my profile.
Regarding watts used to power the Haier 22" LED...
- I took the AC adapter that comes w/ the unit to a couple of electronic stores (radio shack. & fry's)
- both told me that I needed to use a DC cord that powered at 48 watts (4 amps)
- I have no reason not to believe that info as factual
- I'lll search on internet to locate a DC plug that converts 12 volts to 48 watts and has same plug size that'll fit in rear of TV
06-27-2011, 12:31 AM
#52
avocadoman, i can see where you live under your name but i used to live in Ventura County so i know of Channel Islands Harbor quite well.
06-27-2011, 07:04 AM
#53
You can not convert volts to watts. Watts are how power is measured.
Think of volts as water in a big tank. The bigger the tank the more pressure (voltage) is available to go down a pipe of a certain size (wire).
When you hook a water powered device up to the pipe and start it running (open the valve), water flows out of the pipe under the pressure from the tank (measured in volts). The amount of water running past a point along the pipe is the flow (measured in amps).
To find the POWER being used by the device you measure the Pressure available at the outlet of the tank (voltage) and the flow past the point on the pipe (amps) and you get the power the device is using in Watts.
IF the device is a powered pump (short circuit or big honkin hair dryer) the device will try to SUCK water through the pipe. All that water can't FIT in the pipe and the pipe will get hot trying to. Soon the pipe will fail (collapse in the example or catch fire or melt in electricity).
Did that help or hurt?
06-27-2011, 07:18 AM
#54
I am looking at the basic inverter/sine model being about $500; or I could get a basic generator for $200.
The difference between the $200 and the $500 might be noise levels.
Try to find the db rating of any generator you're interested in.
Some are MUCH louder than others.
AND if you only plan to boon dock a couple days a year WHY do you
want a generator???
It's just another gas engine you'll have to keep winterized 99% of the time.
We just boondocked 5 nights in Shenandoah NP and didn't bother to
start our Honda. I wish I'd left it at home as it was taking up valuable
space in the back of my truck!
Peace!
Dan & Rita D
06-27-2011, 08:32 AM
#55
Originally Posted by KyDan
AND if you only plan to boon dock a couple days a year WHY do you want a generator???
I'm going to blame Lou. He's a bad influence on the rest of us.
Wolf Pup T16P owner
06-27-2011, 08:34 AM
#56
What!
