Forest River Forums
Sunline User Photos
Old 06-27-2011, 12:28 AM   #51
Originally Posted by ken0042 View Post
First off- where do you live?
Second, have you confirmed the wattage it's using? My 12" TV is spec'd for 24 watts; but I've never seen it use more than 15 watts.
I live in southern california (usa). Don't know why it doesn't show up as part of my profile.
Regarding watts used to power the Haier 22" LED...
- I took the AC adapter that comes w/ the unit to a couple of electronic stores (radio shack. & fry's)
- both told me that I needed to use a DC cord that powered at 48 watts (4 amps)
- I have no reason not to believe that info as factual
- I'lll search on internet to locate a DC plug that converts 12 volts to 48 watts and has same plug size that'll fit in rear of TV
avocadoman1 is offline   Reply With Quote
Old 06-27-2011, 12:31 AM   #52
Moderators' Assistant
bikendan's Avatar
avocadoman, i can see where you live under your name but i used to live in Ventura County so i know of Channel Islands Harbor quite well.
Old 06-27-2011, 07:04 AM   #53
Lou Amadio
herk7769's Avatar
You can not convert volts to watts. Watts are how power is measured.
Think of volts as water in a big tank. The bigger the tank the more pressure (voltage) is available to go down a pipe of a certain size (wire).
When you hook a water powered device up to the pipe and start it running (open the valve), water flows out of the pipe under the pressure from the tank (measured in volts). The amount of water running past a point along the pipe is the flow (measured in amps).
To find the POWER being used by the device you measure the Pressure available at the outlet of the tank (voltage) and the flow past the point on the pipe (amps) and you get the power the device is using in Watts.
IF the device is a powered pump (short circuit or big honkin hair dryer) the device will try to SUCK water through the pipe. All that water can't FIT in the pipe and the pipe will get hot trying to. Soon the pipe will fail (collapse in the example or catch fire or melt in electricity).
Did that help or hurt?
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 7)
herk7769 is offline   Reply With Quote
Old 06-27-2011, 07:18 AM   #54
volunteer moderator
I am looking at the basic inverter/sine model being about $500; or I could get a basic generator for $200.
The difference between the $200 and the $500 might be noise levels.
Try to find the db rating of any generator you're interested in.
Some are MUCH louder than others.
AND if you only plan to boon dock a couple days a year WHY do you
want a generator???
It's just another gas engine you'll have to keep winterized 99% of the time.
We just boondocked 5 nights in Shenandoah NP and didn't bother to
start our Honda. I wish I'd left it at home as it was taking up valuable
space in the back of my truck!
Peace!
Dan & Rita D
2008 Rockwood 2502 Ultra Lite
2004 5.3L Silverado 1500 ext. cab 2WD
Reese dual cam hitch, AirLift load levelers
53 days camping in 2010, 47 in 2011, 12 in 2012
Old 06-27-2011, 08:32 AM   #55
ken0042's Avatar
Originally Posted by KyDan View Post
AND if you only plan to boon dock a couple days a year WHY do you want a generator???
I'm going to blame Lou. He's a bad influence on the rest of us.
Wolf Pup T16P owner
"The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine." - Abraham Lincoln
ken0042 is online now   Reply With Quote
Old 06-27-2011, 08:34 AM   #56
Lou Amadio
herk7769's Avatar
What!
» Online Users: 503
97 members and 406 guests
0721SSROO, 4bnabird, 87CrewDually, accumack, adp1326, armye7, ashump, BamaCorner, BBuck, Bearcat55, biggrigg, bjlowe, briangoodridge, Cafjackracing, caper, CCrane2299, CHD Dad, chof16, cmptrkd, ColoradoGreg, DAISY BOYKIN, daveg, daveinpickerington, daw592, deerslayer, Dennis Carpenter, Dodge Guy, DonCath25ds, dunnnc, Elidh, Emptypockets, gerrym51, Glockfanjohn, Great Horned Owl, Great Lakes, gtkato, gvanmeter, Happy Vibe, HemiCab, hitch hiker, hoovercab, Hybrid21SS, Itsthetwoofus, J McClure, jamiller45, Jestercyco, jmswms, Joe Gag, kegoneill, ken0042, KKapa, Kricket, lbhird, leencharlotte, lmcleister, Lonewolfcry, Magnetic, Mattpopp, mcbride5, merlin66043, mike7431, MilCop4523, MIwolf, Mkayers, MrAllen, msbates, mtnguy, NanaKaren, OffPavement, Poppy Bill, pwrplay, Reneedann, retiredguy, rracer5, Rugged Brown, SabreSam, Sailfish Bret, Saratoga Camper, sbond, Scriggs1, shawnj72, shurack24, slogan, stevengb, Tbeasley77, tentcamper1, TheSasks, tiny, TRAVLINOHIO, Triguy, trudinator, vlite2011, vp22er, wagon52, WalnutTree, whj77372, wildwood_man
Most users ever online was 996, 05-22-2012 at 11:04 AM.
Close [X]
