04-17-2011, 07:41 AM
traveler
Generators & Boondocking
Somewhere in one of the threads it was suggested that one could purchase a Gas Generator. Could you expect to run the bare essentials on the TT using a generator. Obviously there are benifits having your own power generator at the site, but could someone explain a bit deeper.
2011 Ram 1500 Quad Rockwood 8315 BSS.
2010:21 sleeps 2 provinces 2011:47 sleeps 13 states-3 provinces
"We travel, initially, to lose ourselves; and we travel, next to find ourselves. And we travel, in essence, to become young fools again- to slow time down and get taken in, and fall in love once more."
— Pico Iyer
04-17-2011, 07:54 AM
Moderator
A good 3000 watt generator will run pretty much everything in a trailer. You however cannot run the A/C and say a coffee maker at the same same time with a 3k. You would need to look at something like a pair of Honda Eu2000's jumpered together in that case.
John & Deb
2008 Dodge Ram 2500 4x4 Laramie Hemi Megacab
2011 Flagstaff V-Lite 30WRLS
04-17-2011, 08:13 AM
You can run from the "bare essentials" to everything in the TT depending on the size of the generator. The Hondas and the Yamahas are popular because they are quiet, dependable and provide a consistent power source safe for use with electronics such as computers. Some of the less expensive (non-invertor models) can have power spikes.
1000 watt - charge batteries, run lights & misc (will not run AC or microwave)
2000 watt - charge batteries, run lights, microwave (will not run AC)
3000 watt - charge batteries, run everything but not AC and microwave at same time
4000 watt - will run everything as long as you have a single AC unit
We have 2 Honda EU2000i generators with a parallel kit. We went that route over a single larger unit, because they are lighter and easier to move around than a single larger unit. When boondocking I will run one about every three of four days to recharge the batteries. We try to mostly run off the batteries, which will run everything except the microwave and AC. One will run everything except the AC. We run both when we need the AC.
Hope this helps.
Glenn & Beth (Dad & Mom)
David & Audra (11 year old twins)
04-17-2011, 01:43 PM
Moderators' Assistant
reinreb, i'd seriously look at your TV. you made the mistake by believing the dealer, which you should never do.
IMHO, a 34' TT with a GVWR near 9000lbs., is in 3/4 ton land, not 1/2 ton land even with a Hemi.
that said, having a generator allows for more camping options. dry camping and boondocking can open up whole new areas and places to go, without needing hookups.
we primarily dry camp and shun RV parks. our state parks have virtually no sites with electric, so a generator is a must.
some campgrounds will have generator hours or certain restrictions.
one of the biggest issues with generators is noise level. educate yourself on decibel ratings.
for boondocking, noise levels aren't as big a concern, except for the owner.
for that size RV, you'll have at least one 15k a/c, if not two 13.5k a/c's.
i also suggest two Honda/Yamaha 2000 units to parallel. you'll only need the second one for the a/c, otherwise one is sufficient. and they only weigh 50lbs. each and are the most quiet made.
you just plug in the shore cord and fire it up.
04-17-2011, 03:05 PM
traveler
I'm going to start another Topic in General Tech and Repair addressing the weight questions and points.
— Pico Iyer
04-17-2011, 05:19 PM
I bought a cheap 3500 watt generator and it will power my AC and micro at the same time. It is suprisingly quiet but not on the level olf a Honda. I use it when we boondock at a friends farm but not sure if I would use it in a campground.
2010 Flagstaff 25 DS
2004 Dodge 2500 Hemi
04-18-2011, 07:44 AM
volunteer moderator
Glenn, I think you're right on with this!!
Peace!
Dan & Rita D
2008 Rockwood 2502 Ultra Lite
2004 5.3L Silverado 1500 ext. cab 2WD
Reese dual cam hitch, AirLift load levelers
53 days camping in 2010, 47 in 2011, 12 in 2012
04-28-2011, 04:32 PM
The Yamaha EF2400 generator is quiet and will run a newer 13.5K AC unit, as well as other "basic" stuff, but not a MW,Coffee maker etc.
-2009 Ford F-150, SuperCab w 8 ft bed
5.4L Screw, 3.73 rear, 8200 GVWR
-2011 Rockwood 2604, 2x6V Interstate U2200 batteries,Yamaha 2400 genny
-2011-23 nights
04-28-2011, 06:02 PM
Location: Jacksonville Florida - Home of the Jaguars !!!!
I have a Gen Pro 3500 RV generator that is rated at 67db and has a 30 amp RV specific plug-in, and one 15 amp standard double 15amp plug, and a 12 volt charge plug. It is also electric start, or rope start, and has a 6.5 hp engine. It runs my AC, and an electric skillet at the same time, with lights on, as well without any trouble. 479.95. NO, it's not as quiet as a Honda or Yamaha, but it is less than half of the price, and I really don't go boondocking but 2 or 3 times a year, max. It works fine for me! Randy
 '08 V-lite Flagstaff 30WRLS
'06 Ram 1500 QC hemi  Reese dual cam sway control,
K&N series 77 intake, Hellwig pro series helper spgs.
'04 Durango Limited Hemi, '72 Mach One 351 cj
04-30-2011, 11:07 AM
I'm not sure why a generator is such a must? I do have one it is only a 1300 watt and in the last 2 years I bet it only ran 5 hours.
I only use it to charge up the battery if we stay in 1 spot for or 5 days.
if you have a good battery it will hold the power for a long time.
Who needs all them electric gadgets like a coffe maker, blenders for the slushy drinks etc.
we go camping for peace and quiet.
I find it actually very anoying when there are generators running all the time, to me might as well stay home and listen to all the lawnmowers that go off in the neighbourhood.
One lawnmower shuts off and another one on the other side starts up and that seems the same with generators at campground.
sorry for the rant.
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 511 |
| 101 members and 410 guests |
| 0721SSROO, 4bnabird, 87CrewDually, accumack, adp1326, armye7, ashump, BamaCorner, BBuck, Bearcat55, biggrigg, bjlowe, briangoodridge, Cafjackracing, caper, CCrane2299, CHD Dad, chof16, cmptrkd, ColoradoGreg, DAISY BOYKIN, daveg, daveinpickerington, daw592, deerslayer, Dennis Carpenter, Dodge Guy, DonCath25ds, DonG, dunnnc, Elidh, Emptypockets, gerrym51, Glockfanjohn, Great Horned Owl, Great Lakes, gtkato, gvanmeter, Happy Vibe, HemiCab, hitch hiker, hoovercab, Hybrid21SS, Itsthetwoofus, J McClure, jamiller45, Jestercyco, jmswms, Joe Gag, jusme, kegoneill, ken0042, KKapa, Kricket, lbhird, leencharlotte, lmcleister, Lonewolfcry, Magnetic, Mattpopp, mcbride5, merlin66043, mike7431, MilCop4523, MIwolf, Mkayers, MrAllen, msbates, mtnguy, NanaKaren, OffPavement, Poppy Bill, pwrplay, Reneedann, retiredguy, rracer5, Rugged Brown, SabreSam, Sailfish Bret, Saratoga Camper, sbond, Scriggs1, shawnj72, shurack24, slogan, Stank Bait, stevengb, Tbeasley77, tentcamper1, TheSasks, tiny, TRAVLINOHIO, Triguy, trudinator, vlite2011, vp22er, wagon52, WalnutTree, whj77372, wildwood_man, wnytaxman |
| Most users ever online was 996, 05-22-2012 at 11:04 AM. |
