Forest River Forums
Sunline User Photos
Old 05-02-2011, 07:00 AM   #1
volunteer moderator
Generators and StaBil and Ethanol (oh my!)
Just when we thought we had this generator and gas and
long term storage figured out there's this.
My son has a muscle car. GTO cherry under 10K miles.
He only drives it in dry summer weather.
He uses stabil like many of us in our generators and
lawn mowers and boats and motorcycles.
This spring he got the car out and it started and ran
but was under powered and had a rough idle.
(Rough is a relative term- he has a semi race cam
in it.)
Long story but the jist of it is he looked online and
the hot rod muscle car crowd has found that ethanol
separates from the gas during storage.
Apparently StaBil doesn't prevent this.
He said he siphoned a lot of it out and put some in a
jar and you could see 2 layers in the gas.
He gave it to his buddy to burn in his daily driver and
now only puts a small amount in his GTO so he can
burn it on short trips. He basically buys a couple gallons
each time he takes the car out and tries to park it close
to empty.
I have not googled this subject but let the discussion
begin!
Peace!
Dan & Rita D
2008 Rockwood 2502 Ultra Lite
2004 5.3L Silverado 1500 ext. cab 2WD
Reese dual cam hitch, AirLift load levelers
53 days camping in 2010, 47 in 2011, 12 in 2012
Old 05-02-2011, 07:04 AM   #2
Lou Amadio
herk7769's Avatar
I have actually heard about this before, but did not think about the implications to the RV world.
The discussion came up among "boat people" who winterize their boats. They put them away with full gas tanks for some reason and a discussion about additive separation was what I "over heard." That must have been what they were talking about.
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 7)
herk7769 is offline   Reply With Quote
Old 05-02-2011, 07:15 AM   #3
papap's Avatar
Ethanol attacks water and a boat tank is vented. so if you put it away empty it attracks more water into the tank. Stabil does make a marine Ethanol treatment now.
papap is offline   Reply With Quote
Old 05-02-2011, 07:24 AM   #4
volunteer moderator
FYI the GTO is late model, last year they were made.
So it has sealed fuel system, unlike a boat that is vented.
Old 05-02-2011, 07:32 AM   #5
Moderator
TheSasks's Avatar
Use Seafoam. It is one of the most used products out there and it plain works as advertised. FYI Stabil in the bottle only has a shelf life of 2 years max, so if he had the bottle of stabil laying around for any time it was probably bad to start with. When I used to use it I only kept it for the year I actually bought it, but I use seafoam for everything now from adding a can to the gas tank every 10k to a fuel stabilizer to doing the though the brake booster vacuum line clean up.
From your last post I am now assuming it is the Aussie GTO with the Vette style fuelie small block, so ya it shouldn't have any issue running ethanol blend fuel.
http://www.seafoamsales.com/how-to-u...treatment.html
John & Deb
2008 Dodge Ram 2500 4x4 Laramie Hemi Megacab
2011 Flagstaff V-Lite 30WRLS
TheSasks is online now   Reply With Quote
Old 05-02-2011, 09:34 AM   #6
I don't know the ins and outs of how these additives work. But I use sea-foam and Phase Guard 4 in everything. Phase 4 for storage over 30 days, and the sea-foam in the spring for cleaning the systems. I've stored fuel for over a year and never had issues with any of my equipment, generators, or vehicles. Some which is pretty old. I buy them at Fisher Auto. I've also used the sea-foam after it's sat on the shelf for 2 years plus, with no ill effects.
GrowingGoatee is offline   Reply With Quote
Old 05-02-2011, 09:52 AM   #7
Moderator
TheSasks's Avatar
I was talking about the Stabil having a shelf life not Seafoam. BTW seafoam is a very good stabliizer and can be used to store fuel for up to 2 years.
John & Deb
Old 05-02-2011, 10:02 AM   #8
I know, just giving my experience with what I use.
Old 05-02-2011, 01:22 PM   #9
volunteer moderator
He has issues with ethanol.
Here's his specs.
Note the HP listed is actual dyno tested at the rear wheels.
364cu in 6.0L LS2 aluminum block and heads pushrod v-8
Replaced from stock - L92 heads, valves, springs, rockers, ceramic coated
headers, 3" dual exhaust, L76 intake manifold, mild livernois cam, .040
stainless cometic head gaskets to keep the compression up, ARP head bolts,
3.91:1 gears in the rear, Hankook drag radials out back.
Compression is around 10.9:1, and the engine currently makes 540Hp.
0-60mph in 4 seconds, 0-100 in under 9 seconds.
Peace!
Dan & Rita D
Old 05-02-2011, 03:22 PM   #10
Moderator
TheSasks's Avatar
Here's his specs.
Petty impressive machine Dan. IMO Seafoam would work well for that machine, those late model small blocks are monsters. Alot of marine people rely on it with their high $$ machine.
John & Deb
» Online Users: 530
110 members and 420 guests
0721SSROO, 4bnabird, 87CrewDually, accumack, adp1326, armye7, ashump, BamaCorner, BBuck, Bearcat55, biggrigg, bjlowe, briangoodridge, buzzmonster, Cafjackracing, caper, CCrane2299, CHD Dad, chof16, cmptrkd, ColoradoGreg, DAISY BOYKIN, daveg, daveinpickerington, daw592, deerslayer, Dennis Carpenter, dewcew72, Dodge Guy, DonCath25ds, DonG, dunnnc, Elidh, Emptypockets, Falcon35, FR28footer, gerrym51, Glockfanjohn, Great Horned Owl, Great Lakes, gtkato, gvanmeter, Happy Vibe, HemiCab, hitch hiker, hoovercab, Hybrid21SS, Itsthetwoofus, J McClure, jamiller45, Jestercyco, jjm901, jmswms, Joe Gag, jusme, kegoneill, ken0042, kgmat, KKapa, Kricket, lbhird, leencharlotte, lmcleister, Lonewolfcry, Magnetic, Mattpopp, mcbride5, merlin66043, mike7431, MilCop4523, MIwolf, Mkayers, MrAllen, msbates, mtnguy, NanaKaren, OffPavement, pg_rider, Pinesman, Poppy Bill, pwrplay, Reneedann, retiredguy, Rickstermn, rracer5, Rugged Brown, rvinman, SabreSam, Sailfish Bret, Saratoga Camper, sbond, Scriggs1, shawnj72, slogan, Stank Bait, stevengb, Tbeasley77, tentcamper1, TheSasks, tiny, TRAVLINOHIO, Triguy, trudinator, vlite2011, vp22er, wagon52, WalnutTree, whj77372, wildwood_man, wnytaxman
Most users ever online was 996, 05-22-2012 at 11:04 AM.
Close [X]
