Old 06-04-2015, 05:47 PM   #1
How long does it take?
If your battery is low or completely drained how long would it take for a generator to charge it up? I'm thinking a 2000w honda. Possibly 2 of them hooked together if need be. Thanks.
larryo is offline   Reply With Quote
Old 06-04-2015, 06:15 PM   #2
My yamaha EF2000ie says about 4 to 5 hrs.
uhduh camping is offline   Reply With Quote
Old 06-04-2015, 08:36 PM   #3
Is that with the trailer plugged into the generator or charge cord from the gen to the battery?
Old 06-04-2015, 08:50 PM   #4
Charging cables from gennie to battery. I have not tried to charge thru the inverter with battery that low.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
Old 06-04-2015, 10:14 PM   #5
TURBS's Avatar
Converter not inverter.
How low is low?
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "9 nights"
Old 06-04-2015, 11:12 PM   #6
Don't know? The places I like to camp at have limited number of serviced sites so will dry camp. I would like to run the furnace at night and recharge the battery the next day. I understand that the furnace will drain the battery in one night. Also, does your Yammi power your a/c?
Old 06-04-2015, 11:35 PM   #7
SKnight's Avatar
It's true heavy furnace use will kill a battery pretty flat. Depending on your converter size, it will charge up in a few hours of fun time.
If you do a lot of dry camping you'll likely end up converting to a multiple battery setup, dual 12v or 6v, ending up with 200ah or more.
I dry camped last fall, in sub 30* temps. I've got four 6v batteries in a split parallel arrangement giving me a total of 460ah. Furnace set to 50* and running my cpap, I would be down about 70-75% or 12.4v. It would take about two hours for my converter to reach float mode, on one Honda EU2000i.
You need two 2000w units to run your AC, but one will run everything else.
Old 06-04-2015, 11:45 PM   #8
Thanks. The trailer is new to us so I can't say how much we will dry camp, but it's a great excuse to get a nice generator!
Old 06-05-2015, 11:42 AM   #9
Instead of two 2000 watt generator get a Honda 3000 watt unit. It will run your air with no problems and is less expensive.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 06-05-2015, 11:58 AM   #10
NCBBA11043's Avatar
Not sure if a Honda 3000 will power a 15K BTU A/C unit. They (Honda) say it will work with 13,500 BTU A/C, but others here have stated that's not always true. A lot of discussions about (2)2K's vs 1 3K. (2)2K's cost about the same as (1)3K, and are a lot lighter. They have smaller gas tanks, so runtime is shorter (buy an external tank setup).
NCBBA11043 is offline   Reply With Quote
